Raspberry Pi Forum how do i connect my rpi using ethernet cable
  • Replies 16 replies
  • Answers 8 answers
  • Subscribers 678 subscribers
  • Views 2520 views
hi,
I've recently bought rpi model b+ and am facing problems in connecting it to my laptop as an error occurs every time i run putty software. I'm following the instructions given in the following video.
http://www.youtube.com/watch?v=xarq3PI5zTw
please suggest other by whch i can connect rpi to my laptop. i do not have an external screen.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    what are the errors your getting
    this will help to advise you
    Peter
    0 Former Member over 11 years ago in reply to Robert Peter Oakes
    Thank you for responding to my question.
    The error that I'm getting is "putty fatal error, the connection was refused"
    I don't know what should I do in order to establish the connection.
    secure shell
    Do I need to follow steps other than the ones shown in the video in order to establish the connection by secure shell?
    0 Robert Peter Oakes over 11 years ago in reply to Former Member
    I just created this, it should help, http://www.element14.com/community/community/raspberry-pi/blog/2014/10/03/first-time-login-top-pi-b-b-using-ssh
    Regards
    Peter
    Hey,
    Thanks a lot for your efforts.
    I'm afraid I still am getting the same error on giving the ip address and on putting the host name it says " unable to open raspberrypi, host does not exist. "
    If you connect the PI to an HDMI screen along with keyboard and a network connection
    Run this command
    pi@raspberrypi ~ $ ifconfig
    it should return stuff like this
    eth0      Link encap:Ethernet  HWaddr b8:27:eb:5f:e0:68
              UP BROADCAST MULTICAST  MTU:1500  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:8 errors:0 dropped:0 overruns:0 frame:0
              TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:1104 (1.0 KiB)  TX bytes:1104 (1.0 KiB)
    wlan0     Link encap:Ethernet  HWaddr 00:13:ef:d0:23:98
              inet addr:192.168.1.229  Bcast:192.168.1.255  Mask:255.255.255.0
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:435567 errors:0 dropped:7234 overruns:0 frame:0
              TX packets:3242 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:330166230 (314.8 MiB)  TX bytes:647233 (632.0 KiB)
    In my case im connected via WIFI and you can see under wlan0 my IP address
    You may well have a different ip
    Whatever you have, try to ping it from your computer, this atlest will tell you if you have connectivity
    The other possibility is you did not enable SSH during install so from the console you will need to follow these instructions to enable it
    http://www.raspberrypi.org/documentation/remote-access/ssh/
    This still means you will need to connect a keyboard and HDMI screen to your PI to complete the task, once that’s done you wont need the keyboard or screen
    Regards
    Peter
    Thanks a lot Peter. I'll try with an external screen. Thanks for help image
  • rew
    0 rew over 11 years ago in reply to Former Member
    Hi Anjani,
    The "connection refused" means that there is no ssh deamon waiting for you to  connect.
    In the beginning, it was deemed "unsafe" to start the ssh deamon on "out-of-the-box" raspberry pi's. You had to edit a file in the boot partition, or run raspi-config on the console to enable it.
    That situation would cause the effects you're seeing.
    Nowadays, last few pi's I've installed, the ssh deamon is turned on by default. This eases things for you and me who are going to use the 'pi without a screen. Either I don't even have a screen-and-keyboard or it's a hassle setting it up for just a few minutes until ssh works.
    So are you using the official raspian image? How old?
    0 Former Member over 11 years ago in reply to rew
    Hey Roger,
    I'm sorry for replying so late.
    I'm using the latest version of raspian image, the one that is available on the official site of raspberry pi.
  • rew
    If you're using the right IP address and you're getting "connection refused" then that trumps my "I thought the SSH daemon was enabled by default nowadays".
    The fun with Linux is that you can examine the source of everything that happens to be able to say more about how things work or you you can manually cause things to happen. As in this case.
    If you use raspi-config it calls "update-rc.d ssh enable" to enable ssh. What this does is it creates a link from /etc/rc2.d/S02ssh to /etc/init.d/ssh .  (for completeness, it does this too in the rc3.d, rc4.d and rc5.d directories, but at this point in time those don't matter. So once you can access your raspberry pi, I recommend you dis/enable it once more with raspiconfig to prevent future surprises. )
    So if you can mount the sd card on another Linux machine you can create that link, and it should work.
  • mikepowell
    0 mikepowell over 11 years ago in reply to rew
    I think most things have been covered here:
    1. Make sure the Ethernet socket of your laptop is MDI-X compatible (that means you can connect Ethernet devices directly together - in the past this was not possible except via a Ethernet switch or a hub).
    2. Find out the IP address of your Raspberry Pi. For example 192.168.1.23.
    3. Set your Windows computer to static IP, rather than via DHCP.
    4. Set your Windows computer IP address to a static address in the range 192.168.1.1 to 192.168.1.254. I normally choose 192.168.1.1.
    5. Set gateway address to be your Raspberry Pi address, 192.168.1.23.
    6. Leave DNS settings blank.
    7. Make sure the SSH service is started on Raspberry Pi. I believe the command should be service sshd start. You need a screen for this bit. You might need to research how to ensure SSH starts when Pi boots up. This should be easy to find.
    8. If you still have problems after this, switch Windows Firewall off.
    9. You should be able to login using the default username and password.
    I hope this works out.
    Mike.
  • mikepowell
    Mike.
