Forum Colorsound Power boost noise issue
  • Replies 132 replies
  • Answers 52 answers
  • Subscribers 181 subscribers
  • Views 18231 views
  • colorsound power boost issue
Andy Betts
Andy Betts over 8 years ago
A while ago I posted regarding transistors etc for a Colorsound Power boost clone pedal I was working on. Well, after many months I've actually finished 2 of them... They are identical to an original right down to the size of the PCB.and the components used. There is one slight difference in so far as the first board was a direct print from an Eagle layout, the second board was a 121 trace of an original PCB, only slightly different from the eagle board.
This is the Eagle board
This is board 2, a 121 copy of an original Colorsound Power boost PCB, and also a photo of an original
The component side is like this.. mine is on the left, the genuine PCB is on the right. The pots on my board are mounted to the board like the original... Just from the other side. The reason for this is purely down to the thread length on the pots. The thread on my pots isn't long enough to go through the PCB, and then through the enclosure as well.
20264850_10155652356109783_7777668817152516572_n.jpg?oh=d17440c16b7064d06164d2a2c9783dba&oe=59EEEC46  image
The schematic used was this one..... a simple circuit which is basically a pre-amp that boosts the volume and treble and bass.
The components on the first board were all brand new, where the components on the 2nd board were mostly NOS for a visual vintage vibe.
I have an issue on both boards that I'm trying to troubleshoot, and currently i have reached out to 2 DIY effect pedal forums with no real resolution. i'm hoping someone here may be able to point me in the right direction, i'll try to give as much information as possible.
I have a cycled ticking noise that increases in volume when you turn the volume up on the pedal. it's not affected by the guitar volume, and stays there even when you turn the guitar down. Check out this video.
This video is unavailable.
The last video shows a slight earth problem that may or may not have anything to do with the noise. i thought i'd include it anyway.
I have taken voltage readings off my pedal, and compared them to the readings from a genuine pedal (I'll say at this stage that my pedal is exactly the same as the genuine pedal as regards component values)
Genuine Pedal voltages
Battery: 18.84V
Q1 C 6.43V B 3.92V E 3.54V
Q2 C 11.53V B 6.44V E 5.82V
Q3 C 10.19V B 2.77V E 2.23V
My voltages:
Battery: 18.80V
Q1 C 6.37V B 3.90V E 3.52V
Q2 C 11.36V B 6.37V E 5.74V
Q3 C 10.54V B 2.75V E 2.19V
    jw0752 over 8 years ago +6 suggested
    Hi Andy, and Others, Tonight I breadboarded the two transistor input amplifier so that I could see what was happening . Here is my bread board set up. I am using 2N2222 2N2222 transistors and otherwise…
    michaelkellett over 8 years ago in reply to Andy Betts +6 suggested
    This has got me so intrigued that I'm unwilling to let it go as an unsolved mystery. If you want to send me the non working board I'll look at with a scope etc and report back on E14. MK
  • Andy Betts
    Andy Betts over 8 years ago in reply to michaelkellett +6 verified
    Thanks Michael, I have a very good update...... I think I've discovered what's causing the issue. I got home from work early, and while there was nobody in the house I started turning things off......…
  • Andy Betts
    0 Andy Betts over 8 years ago
    Michael, The PCB has been sent today, it's been sent special Delivery so you should get it tomorrow before 13:00.
    The soldering is not good after having another look at it, especially around the transistors.... This is down to the swapping out of components etc. probably needs trashing now and starting again.... See what you think
    Andy
  • Andy Betts
    0 Andy Betts over 8 years ago in reply to Andy Betts
    Michael, as a heads up.... When you get the board check the 22uf cap between the emmiter of Q1 and pin 1 of the volume pot.... This might be the root cause, or something to do with it.
    I just soldered this into another board and when i touch the volume pot i hear slight motor boating, but not when i DON'T touch it... It didn't happen before i soldered this cap in.
    0 michaelkellett over 8 years ago in reply to Andy Betts
    Hello Andy,
    I just received your board and connected it up with a lab power supply, signal generator and scope - it seemed to work fine.
    So I connected it up with batteries, signal generator and Chord practice amp - still fine.
    I don't have a guitar at work so I'll bring one in tomorrow.
    I'm not sure if this is good news or bad !
    What power supply were you using.
  • Andy Betts
    0 Andy Betts over 8 years ago in reply to michaelkellett
    Batteries.... I was using batteries
    It's fine???
    Now, that's weird... It was motor boating without a guitar, you heard the video!! With the volume right up it sounded horrid.
    This may sound a bit pedantic but I'm struggling to pin down differences, what kind of batteries ?
    The ones I used were Duracell  "Industrial" alkaline batteries straight out of the box. I'm wondering if power source impedance matters (I'll test for that soon.)
  • Andy Betts
    Ok, the batteries were brand new "Energizer" batteries. I do have a 18v DC power supply to that I could try.
    The board I have here is running perfectly... With no issues.
    Energizers should be OK - I'll still explore the possibility.
    I probably won't be able to do much on until the weekend now - but you might get lucky if real work hits a boring patch.
  • Andy Betts
    Many thanks for taking the time..... i'm interested in why this is happening even more now.
    I connected your board up to a guitar and amplifier running off the new Duracell batteries - no problems and certainly no motorboat noise.
    I then tried a 100R resistor in series with the batteries and still no problems.
    Did you test the board out of the metal box - I'm wondering if something might have been shorting to the box, or possibly a problem with the switch wiring.
    I can't think of anything else useful I can do with it  - so let me know if you can think of any other tests - otherwise I'll send it back to you.
    0 jw0752 over 8 years ago in reply to michaelkellett
    Hi Michael,
    Is there a chance that the board is overdriving Andy's guitar amp and the guitar amp is actually what is causing the motorboating?
    0 michaelkellett over 8 years ago in reply to jw0752
    It's not very likely because Andy's recording shows that the noise can occur when there is no other signal, and with the guitar volume control turned right down.
  • Andy Betts
    This is very strange indeed.... Could it be some kind of interference peculiar to my house?
    For the record, i tested the board mostly out of the enclosure, as you could see in the videos.... I have built another board and that is ok, (although the motor boating is there very faintly when on the highest gain setting)
    I'm at a loss............. The evidence was there.... So what could it be?
    Send it back.... i'm going to take it to a friends house and try it through his valve amp, and see if it happens there..... I'll report back findings.
    One question Michael.... What do you hear when the pedal is at full gain..... as that is when it seems to be at its worse?
    Hello Andy,
    It's all OK at full gain, quite a bit of hum from the cheapo guitar but no other problems.
    We've got a digital audio recorder at home so, if you are not in a rush to get it back I'll bring the recorder in and make some recordings for you.
  • Andy Betts
    A recording would be great... Not that i disbelieve you at all... Just want to hear what you hear.
    now the second question, could it be the guitar wiring?? This guitar wasn't wired by me, the pickguard was bought ready assembled, all i had to do was wire the jack socket and attach the earth wire to the tremolo claw. This is the assembly that I bought about 7 years ago
    http://www.stratcat.biz/4035.shtml
    All the  components are of the highest quality possible, and have not caused me any issues before. However, that's not to say something may have degraded or come loose in the last 7 years.... saying that It can't be the guitar as I've experienced the noise without having the guitar plugged in....  image
    I'd be very surprised if the guitar made a difference - on any I've seen the volume control shorts the signal to ground at minimum setting and that's going to leave you with just the cable impedance shorting the input of the pedal - and your board seems quite happy with that.
  • Andy Betts
    i didn't think it could be the guitar...... Clutching at straws now for an explanation
