PCB Design, Prototyping and Production
PCB Forum soldering MLF chips in pcb
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 134 subscribers
  • Views 549 views
  • chip
  • soldering
  • mlf
Ax111_
Ax111_ over 3 years ago
I was wondering if there is a chip socket for Quectel EC25U to solder it in a 2 layer PCB. Since it has its pin underneath it, is there any possible alternative for it.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago +5
    There are usually no sockets for custom modules like this one. Depending on signals on the center pads, you could put plated through holes, that are smaller than the pad on the board and let solder flow…
  • wolfgangfriedrich
    0 wolfgangfriedrich over 3 years ago
    Depending on signals on the center pads, you could put plated through holes, that are smaller than the pad on the board and let solder flow into the hole to connect to the package pads. Tricky but not impossible.
    In any way, this is a cursed footprint.
    • Vote Up +5 Vote Down
  • wolfgangfriedrich
