Member's Forum Christmas holiday plan: repair a 60s turntable
  • Replies 21 replies
  • Subscribers 564 subscribers
  • Views 5523 views
  • vintage
  • td124
  • thorens
Jan Cumps
Jan Cumps over 2 years ago
I have a turntable from the mid-60, Thorens TD 124. It has a mechanical issue: the speed selector has a worn-out component.
This holiday I'll see if I can fix this. These tables, and the components, go for crazy prices (check ebay for anything related to a TD 124, it's a strange world out there).
The worn component is part of this contraption:
    Jan Cumps over 2 years ago +6
    Worky: https://youtu.be/8tMOoV7XueE
    Jan Cumps over 2 years ago +3
    It turns out that I'm lucky. The part isn't worn, but lost grip. Symptom: the outer ring should turn the speed switcher, when it's turned by the plate steel belt. But it slips. Cause: the speed switcher…
    genebren over 2 years ago +2
    Good luck on your repair plan!
    needledrop: Janis Ian and Giorgio Moroder: Fly Too High. (c)&(p):1979 CBS Inc. Fair use.
    Recording (mp3cut.net).m4a
    Sampled with the SoundBlaster external soundcard that shabaz  sent me.
    shabaz over 2 years ago in reply to Jan Cumps
    Hi Jan,
    That sounds great! Awesome repair work.
  • colporteur
    colporteur over 2 years ago in reply to Jan Cumps
    Looks like you spent some elbow grease and wiped down surfaces or was the plastic cellophane removed:)
    Jan Cumps over 2 years ago in reply to colporteur
    Grinning it was clean, just gathered dust from being stored away for about 3 years.
    I lost the photos of how it looked like when I bought it. It was sitting inside a tent in a yard sale, on a table in a puddle of water.
    I also lost videos and photos from when I took apart the motor and the complete tonearm.
    Still surprised to this day that I managed to get that tonearm (and it's plethora of ball-bearings) back together. Cheapest replacement I can find online (with issues) is above 400€.
    Jan Cumps over 2 years ago in reply to Jan Cumps
    correction - I found low res photos back on google photos:
    I could not find any back of the motor teardown, but I found the ones from the tonearm back
