    • Avnet Boards Community
Test & Tools
Test & Tools
Forum What's your favorite through-hole desoldering tool?
  • Replies 42 replies
  • Subscribers 354 subscribers
  • Views 6747 views
scottiebabe
scottiebabe over 2 years ago
I have a $5 solder sucker that is nothing fancy for desoldering through hole components. For occasional use it works well enough I suppose.
There appears to be a number of "fancier" solder suckers on the market like this made in japan model:
There are also some inexpensive vacuum desoldering tools, like:
I don't know if it is total junk or a diamond in the rough...
  • scottiebabe
    scottiebabe over 2 years ago +4
    There also appears to be heated suckers: I didn't know they even existed...
  • Andrew J
    Andrew J over 2 years ago +3
    I use this: https://cpc.farnell.com/duratool/d00672/desoldering-station-uk-eu-plug/dp/SD01384 It works pretty well and I've desoldered lots of stuff off prototype boards to reuse. I think Multicomp…
  • beacon_dave
    beacon_dave over 2 years ago in reply to Andrew J +3
    Perhaps take a look at: /challenges-projects/element14-presents/workbenchwednesdays/w/documents/5300/workbench-wednesdays-37-desoldering-wick-tips-and-tricks-with-superwick?ICID=workbenchwed-episode…
  • anniel747
    anniel747 7 months ago
    scottiebabe Shop air powered Weller WDD80V and DSV80.
  • KC7HP
    KC7HP 7 months ago in reply to anniel747
    I followed the general progression described by others.
    I used an older Ebay weller station (with on-board vacuum pump). It worked long enough that parts were not available when it finally died.  It worked so nice I payed the money for a new one, for hobby use.
    I pick old solder out of the filter cartridges until the fiber pad disintegrates.  I also save the cardboard tube to recycle with my padding, when I finally use up the current supply of filters.
    It can be hard to hit the temperature sweet-spot with production no-lead solder.
  • anniel747
    anniel747 7 months ago in reply to KC7HP
    Nice thing about the DSV80; it uses a reusable glass solder collection chamber.
  • anniel747
