Ask an Expert Forum Cat5 on/off Switch?
  • Subscribers 303 subscribers
  • Views 791 views
See a helpful answer?
Cat5 on/off Switch?
sinmaster
sinmaster over 12 years ago
Is it possible to make a on/off switch for the cat 5 cable that is plugged from my computer to my router. The actual cable from my router to the computer would have a switch/button/dial in between the comp and router. When switched is would disconnect the wires. The result is that there is no hard wired connection from the computer to the router anymore. Kind of like a alternative from disconnecting the cable from the back of the computer.
Is this possible?
I appreciate any help or advice,
ReGards,
Sinmas
  • johnbeetem
    0 johnbeetem over 12 years ago
    You can buy them like this one I found at Amazon by searching for "Ethernet Switch" in Electronics, sorting from cheapest.
  • johnbeetem
