Raspberry Pi Forum RPi Model A or B?
  • Replies 11 replies
  • Subscribers 678 subscribers
  • Views 1555 views
RPi Model A or B?
Last year I purchased what I thought was a Model-A Raspberry Pi from Element-14/Newark (US). Since I later had a project that needed a Model-B, I bought one of those also, a few weeks ago.
Recently, I was checking out the differences between the two models and found that, according to various sources, The Model-B has 2 x USB ports (1 on the Model-A) and an Ethernet port (none on the Model-A) as well as a memory size difference.
Now my "Model-A" has both an Ethernet port and two USB ports so I'm confused. Is it, in fact a Model-B (which I didn't think was around when I bought the first one)? Is my information on the model differences wrong? I would appreciate it if someone could shed some light on this and clear up my confusion.
Also, what's the easiest way to check the amount of memory?
  • merlin13
    0 merlin13 over 11 years ago
    There is indeed some confusion that was created because in some places the original Model B (with only 256 MB RAM) was named Model A. In fact, as far as I know the models are:
    - early Model B with 256 MB RAM, 2 USB, Ethernet - this one is incorrectly named Model A in some places
    - late/current Model B 512 MB RAM, 2 USB, Ethernet - more memory than early Model B but otherwise identical (well, there is also a small difference in GPIO pins)
    - Model A released last year, that indeed has only one USB, no Ethernet and only 256 MB of RAM.
    Hope this helps.
    0 Former Member over 11 years ago in reply to merlin13
    Thanks, John and Merlin. The picture gets much clearer.
    So it would seem I have a Model-B of either 256 or 512 MB RAM. Which makes my final question all the more pertinent. How would I positively check the amount of RAM? Presumably I can do this from Linux or the GUI but I'm not sufficiently familiar with either to know how.
    (Update .... I just went to the hardware wiki link that John provided. It tells me how to check there. So thanks a bunch Guys!
  • devinsheppard
    0 devinsheppard over 11 years ago in reply to Former Member
    Yes it is definitely a B model. Really I dont even see why the went ahead with the A model.
  • devinsheppard
  • merlin13
    0 merlin13 over 11 years ago in reply to devinsheppard
    To be honest, I quite like my Model A. For less than $50 (Pi + dongle + SD card) I have a device always WiFi connected. I know there are other options out there but nothing wireless and capable of running a real OS like RasPi in the same price range. At least nothing that I know of.
  • johnbeetem
    0 johnbeetem over 11 years ago in reply to devinsheppard
    Since the Model A has no Ethernet or USB hub, it draws significantly less power than the Model B.  This makes it a better choice for a battery-operated robot, for example.
    And, of course, the Model A is US$10 cheaper.  RasPi's slogan at raspberrypi.org for a long time was "An ARM GNU/Linux box for $25.  Take a byte!"  This got to be embarrassing when the only board you could buy was $35.  "GNU/Linux box" was kind of misleading too, though RasPi does come in a cute little element14 box suitable for rolling up in your T-shirt sleeve image
  • devinsheppard
    0 devinsheppard over 11 years ago in reply to johnbeetem
    I do see the point in the power consumption and using wifi with a robot, But I still would want that ethernet port. Just me though.
  • devinsheppard
    0 devinsheppard over 11 years ago in reply to merlin13
    The Beaglebone Black comes close but still not as cheap.
