I have had not been able to get it working run all the programmed as explained in the quick start guild I wont to use the button on the piface to control two motors i have downloaded the wiring-pi program sudo nano etc/modprode.d/raspi-blacklist.conf the file comes up empty ?
any with this please
I can run the digital emulator and the LEDS work with override enabled
1 do i need to run all program's in idle mode ?
2 I had a program runing on my other machine but still did not get the piface buttons to work
3 do I need to write a program to get the buttons working ?
4 which is the best way download piface image add to sd card ?
5 or use terminal to download emulator ?
6 do i need both emulator on the raspberry pi for it to work ?
