Raspberry Pi Forum PiFace and RFID for Garage Door Opener
  • Replies 26 replies
  • Answers 2 answers
  • Subscribers 675 subscribers
  • Views 3116 views
Hello community -
I have an idea for a project and need a few pointers. Let me preface by saying that my background does not include wiring or physics of any kind - NOOB image
That being said I have a Model B RasPi, a Wiegand RFID Reader and associated Fob(s) and a PiFace.
I am looking to attach the PiFace to the RFID reader and when there is swipe of a RF fob that matches a database of approved fobs - that the garage door opens. Cool right?
I have one of those keypads - but the buttons stick and its a general pain in the rear.
The RFID reader has the following wires hanging off of it with the descriptions right on the reader -
Red - 5.0-16.0 VDC
Blk-Gnd
Grn-Data0/Data
Wht - Data1/Clock
Drain - Shielded Gnd
Org - Green LED
Brn - Red LED
Yel - Beep
Blu - Hold
So I would obviously need to attach some of these wires to the PiFace - as well as the wires that are currently attached to the keypad to get this working.
Like I said - totally clueless - I am sure I can figure out the Wiegand and code stuff - the wiring itself is where I have no clue image
Anyone have any pointers? This is my first real foray into wiring up things like this.
Thanks community.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    If you can link in the actual part number I may be able to provide some help
    I have been developing a cat flap using RFID
    not much difference between a flap and a garage door (Aside from Size)
    Peter
  • Problemchild
    0 Problemchild over 11 years ago in reply to Robert Peter Oakes
    One issue I was considering Peter is that for a Flap you are right up close to the sensor.
    However if you are in the car you need to be at least a couple of bonnets away from the door and I assume pickup sensor.
    Only way around that is to have some sort of post with the RFID pick up on which you place your rfid fob/card
    0 Robert Peter Oakes over 11 years ago in reply to Problemchild
    Yes I agree but Mike was referring to replacing a keypad rather than a remote
    and yes It is possible to have a reader down the drive way a bit on a post or wall depending on surrounding architecture, hopefully Mike has considered this or will now at least.
    RFID will only work to a few CM normally unless you go to great expense and install one like they have in stores to detect people stealing goods as they walk through the doors (About 4feet high and 2 - 3 feet wide... ) image
    Another option would be to use an RF transmitter maybe NRF24L01 attached to Arduino look alike or custom board to transmit the code, this is actually quite easy and would solve the range issue and still be cheap to implement
    0 Former Member over 11 years ago in reply to Problemchild
    Well this is the start of something bigger I hope. I have car openers. What I eventually want to build is a Siri proxy into this setup. I want to build a home automation setup where I can say Siri lock the house - then it makes sure all lights are off garage is closed and doors are locked. This is just the first step.
    Sent from my iPhone
    Sent from my iPhone
    0 Robert Peter Oakes over 11 years ago in reply to Former Member
    Well then you may want to either add WIFI or a Bluetooth to the garage door end of the system, making it easy to interface to the phone
    0 Former Member over 11 years ago in reply to Robert Peter Oakes
    I already have a nifty wifi dongle that works quite nicely. It's a leftover from a different project.
    Sent from my iPhone
  • Problemchild
    Personally Peter I think the WIFI would be much more practical than the RFID in this case as you will not need additional infrastructure.
    The security is in the ownership of the iPhone which becomes a big RFID and you'll need it to interface with everything else any way .
    BTW how did you get an helpful answer by basically agreeing to my post image
    wearing a mask has definite advantages after all.
