Arduino Forum New Arduino IDE
  • Replies 34 replies
  • Subscribers 414 subscribers
  • Views 4403 views
  • libraries
New Arduino IDE
Workshopshed
There's been a few couple of upgrades to the Arudino IDE over the last month.
Arduino - Software
https://github.com/arduino/Arduino/blob/master/build/shared/revisions.txt
As I'm getting started with the Yun it's nice to see that some of the issues around that have been resolved but I think the feature I'm most interested in is the Library Manager, this should make working on different projects a whole lot easier.
  • gadget.iom
    gadget.iom over 11 years ago +4
    8 Minutes to download.... https://youtu.be/N1ug9-rhSs4?t=1m50s
    balearicdynamics over 11 years ago in reply to neilk +3
    Neil, that's correct. Not only but I have explored a bit and see that the library manager is based on a JSON file including all the last updated library list organised by category. The json file is library_index…
  • WestfW
    WestfW over 11 years ago in reply to neilk +3
    > Microsoft standard software installation rules Sigh. I really hate the way that "Microsoft standard rules" scatter an application all over the disk :-(
  • Workshopshed
    Workshopshed over 10 years ago
    So far I've not found the new library manager to be of much help. I tried adding a library from zip and although that did create a library (in my user area) it did allow that library to reference other libraries which were in the program files folders. The net result was that it did not compile. I move the library over to the same folder structure as the others and it worked fine.
  • Workshopshed
    balearicdynamics over 10 years ago in reply to Workshopshed
    But you can change somewhere in the settings (maybe in the preferences advanced text file) where the libraries are stored. Not sure if this version search in both places (your custom folder and the standard folder of the application) or if you should move all the libraries somewhere else.
  • Workshopshed
    Workshopshed over 10 years ago in reply to balearicdynamics
    Eagle CAD uses symbolic links which works quite well.
    Also under Windows ?
  • neilk
    neilk over 10 years ago in reply to Workshopshed
    Workshopshed Hi Andy, my experience of installing libraries under Windows 7 is a bit happier:  under the 1.6.1 IDE,  I used the existing facility to install various libraries from their .zip files - they were installed in a folder called libraries, under the My Sketches Folder (which I keep elsewhere, and tell the IDE where to find it!!), not within the default Libraries folder.
    I subsequently used the provided uninstall program to remove 1.6.1 before installing 1.6.2. The libraries are still there; 1.6.2 can see them; I can load an example from one of them and it compiles happily.........I'm impressed.
    Separation of the downloaded IDE from "your own" stuff - sketches, external libraries etc seems to mark a big improvement.
    balearicdynamics over 10 years ago in reply to neilk
    I suppose that the fact that your libraries are already visible in 1.6.2 IDE is because the uninstaller only knows the files installed, so the settings files - generated locally by the first run and then modified by the preferences or other ways - are persistent from one setup to another.
  • bobcroft
    bobcroft over 10 years ago in reply to neilk
    Neil,
              I do exactly as you do, keep my sketches in their own folder under the C:\ mysketches .  Libraries are a sub folder under  mysketches.  I put all my downloaded libraries in there and I have never had any problem with any IDE version right up to 1.6.3.  I cannot understand why the default path is something like C:\Windows\users\tomDickHarry\documents\Arduino, what a path!  I also put the manually installed Arduino IDE's directly under the C drive.  The .exe. installed ones go under programs(86).
  • neilk
    neilk over 10 years ago in reply to balearicdynamics
    balearicdynamics Exactly, Enrico, but I think what really pleased me was they are not only visible, but actually useable! So I no longer have to re-install all my extra libraries each time I upgrade the IDE. image That's got to be good.
  • neilk
    neilk over 10 years ago in reply to bobcroft
    bobcroft Hi Bob - in fact I go a little further further. All my Arduino "stuff", except for the IDE installation, Is held on a separate drive and in a top level folder that is synchronised by Dropbox. For me this means that I can work on both my desktop and my somewhat less powerful netbook, provided I install the IDE on both. It's very useful when I want to take Arduino on the road image
    Nice. I make something like because all the essential things are on the Mac hard disks. When I need to work on Arduino under windows from one of the Virtualbox Win machines installed on the mac, I use the same location shared to the virtual machine. Then same on the local network when I use another computer, including a couple of Ubuntu devices.
  • WestfW
    WestfW over 10 years ago in reply to neilk
    Well, assuming that they don't change the way they search for libraries.  (Again!  Which was the only reason you had to reinstall them in the first place.) (although, the previous changes were generally for good reasons...)
