EAGLE User Chat (English) Eagle 3D for Mac?
  • Replies 17 replies
  • Subscribers 180 subscribers
  • Views 2398 views
Eagle 3D for Mac?
Where do I find Eagle 3D for the Mac platform? None of the links I come
across work and I'm pretty sure that I remember having installed it on a
Mac several years ago.
Does anyone know where I can find it, and presumably a version which
works with Eagle 7.3.0. Light on OSX 10.9.5 which I'm using now?
Thanks.
    Hi Logyx,
    If you're looking for the EAGLE UP tool, you can find that at:
    www.eagleup.wordpress.com
    EAGLE ships with eagleidfexporter.ulp which generates a 3D IDF file,
    which you can then take to simplifiedsolutions.com to get a 3D model.
    You can get a 3D pdf for free or if you pay a subscription you can
    additionally generate step and stl files.
    Best Regards,
    Jorge Garcia
    Hi Logyx,
    Best Regards,
    Jorge Garcia
    autodeskguest over 10 years ago in reply to autodeskguest
    Excellent, looks great! Thanks for your suggestion. After a fair bit of
    tinkering around I finally got it to work with the demo file.
    Got to try that out too. Nice to have a second option for 3D modeling.
    Thanks again image
    Hi Logyx,
    Unfortunately they were both disappointing image
    I finally got EagleUp working, and it looked great with the demo file,
    but if I'm not mistaken you need a 3D file for every single component,
    and who has the time to design or collect those for each project you
    want a 3D drawing of? That explains why all my own PCB layouts only
    showed the PCB in 3D, but without any components.
    I don't think I ever needed to do something like that back in the days
    with Eagle3D/POVray, but it's been a while so don't quote me on that.
    Using "eagleidfexporter.ulp" and the generated files uploaded to
    http://www.simplifiedsolutionsinc.com/ (not simplifiedsolutions.com)
    didn't result in any usable 3D PCB with the free downloaded 3D file. I
    may have done something wrong in my inexperience (there are quite a few
    complicated parameters there) but it seems it just made a very
    uninteresting and plain 3D picture, barely of any use at all.
    Is there a way to make the old Eagle3D method work with the current
    Eagle version on the Mac OSX platform?
    Hi Logyx,
    They have a warehouse of ready made components, so you don't have to
    make everything from scratch.
    http://sourceforge.net/projects/eagle3d.berlios/
    This contains the files on the EAGLE side
    Here's the link for Pov Ray download
    http://www.povray.org/download/
    Hth,
    Jorge Garcia
    I'm a little confused about the installation and usage process..
    I've downloaded both POVray (3.7 Mac Unofficial) and Eagle3D
    (eagle3d-img-20110101) from the above links.
    POVray is a stand-alone application apparently which I've put in the
    "Applications" folder on my Mac, but as for Eagle 3D I only see a folder
    with loads of .PNG files after unzipping it. According to the
    Instructables guide
    (http://www.instructables.com/id/Render-3D-images-of-your-PCBs-using-Eagle3D-and-PO/?ALLSTEPS)
    I should have a file named "3d41.ulp" or "3d40.ulp" in my "ULP" folder
    (alongside the Eagle application) but there's no such file pre-installed
    with Eagle nor is it found in the Eagle3D folder.
    L.
    Instructables guide
    Hi Logyx,
    Well that's terrible, I don't have any files for that project and it
    looks like the original site stopped being hosted.I was hoping the ULP
    would be included in the files on that site.
    I'm going to have to defer to other members of the forum to see if any
    of them have a saved version of the utility.
    hth,
    Jorge Garcia
    Am 20.08.2015 um 13:17 schrieb Logyx:
    Hi Logyx,
    you need the file
    http://sourceforge.net/projects/eagle3d.berlios/files/eagle3d_20110101.zip/download
    Unzip it in a location of your choice.
    Move the images you have downloaded, to a subfolder
    'eagle3d/ulp/img'.
    In the eagle-board-editor open the ULP
    'your_location/eagle3d/ulp/3d50.ulp' for 'cadsoft eagle V5' and
    newer.
    At the first use, you have to configure the ULP.
    My English is not very good, but I hope I could you help anyway.
    Friedrich
    On 21/08/2015 23:18, Friedrich Bleikamp wrote:
    you need the file
    Thanks. No wonder it didn't work. I still have some problems and am not
    sure where to look. More about that below, but just to avoid any
    confusion and assure I've installed everything correcly, this is what
    I've done (I have Eagle 7.3.0 on the Mac OSX platform):
    1) download and unzip the Eagle3D image files:
    2) download and unzip the Eagle 3D application files:
    3) move the Eagle3D application files to inside my Eagle application
    folder: /Applications/Eagle-7.3.0/eagle3d/
    4) move all the Eagle3D image files (.png) to a newly created "img"
    folder, the complete path being:
    /Applications/Eagle-7.3.0/eagle3d/ulp/img/
    So now Eagle3D should be installed correctly. Next is creating the 3D
    POV file from within Eagle.
    1) In Eagle, open a board file
    2) Click on the "ULP" icon, select "3d50.ulp" (now located here:
    /Applications/Eagle-7.3.0/eagle3d/ulp/) to create the file
    Now the 3D POV file has been created and can be opened with POVRay (3.7
    unofficial) to create the final 3D image file. Here's where I run into
    problems with this error message:
    Possible Parse Error: Cannot find file 'arrays.inc', even after trying
    to append file type extension.
    "/Applications/EAGLE-7.3.0/Eagle3D/povray/e3d_tools.inc"
      line 25
    Parse Error: Cannot open include file arrays.inc.
    Render failed
    PS: shouldn't the content of the Eagle3D ULP folder be copied over to
    Eagle's own ULP folder or is it correct to have two ULP folders?
    Am 25.08.2015 um 14:36 schrieb Logyx:
    Hi Logyx,
    Unfortunately I have no mac, so I can not try it.
    On Windows, in Povray GUI I can override the default values. I
    give the name of a preference file. In my case: Eadle3D.ini. The
    file has the following contents.
    ;path to Windows font directory
    Library_Path=C:\WINDOWS\Fonts
    ;path to INC files
    Library_Path=C:\Daten\MATTHIAS\POVRay\eagle3D\inc
    ;this is the target for generated images
    ;if this section is commented out, it will be written
    ;into the POVRay file directory
    Output_File_Name=c:\temp\povout\
    ;Format of the image file
    Output_File_Type=S
    ;Type N for PNG
    ;Type S for standard system format (Windows BMP, Mac Pict ...)
    ;Type C for compressed Targa (RLE)
    ;TypeT for uncompressed Targa
    ;Type P for Unix PPM
    ;Settings for animations
    Initial_Frame = 1
    Final_Frame = 1
    Initial_Clock = 0.0
    Final_Clock = 1.0
    I have found an older user guide: eagle3d_e.pdf
    https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCMQFjAAahUKEwj4k6CBwMfHAhVoJnIKHdnTD7E&url=https%3A%2F%2Fdocs.google.com%2Fviewer%3Fa%3Dv%26pid%3Dsites%26srcid%3DZGVmYXVsdGRvbWFpbnxsdWNhcm9ib3R8Z3g6NzIyODg1MzY5YTlmMzc2MQ&ei=zRXeVbj5AujMyAPZp7-ICw&usg=AFQjCNGSS0BM_QPlo21Jd8-_sF5lkbYxKA
    Here you get a GUI for the Mac
    http://megapov.inetart.net/povrayunofficial_mac/index.html
    The file arrays.inc should be located in the directory
    POV-Ray/v3.7/include
    For clarity I would put the 3dulp in its own directory.
    Friedrich
