Hello all!
My sprinkler controller is starting to act up and it's so old I can't find replacement parts!
So I'm thinking of using a Raspberry Pi to control the valves. I've noticed online opensprinkler.com has done this before. I like their setup, and might also buy their solution, but being a DIY Maker type I'd like to also try this myself.
The very first thing I noticed is that the valves are all made to run on 24v AC. The old sprinkler controller has a 24v AC adapter.
I have TIP120 transistors, but I can't tell by the datasheet if it can be used to switch AC voltages.
I also have TOP223Y transistors, which do state that they can switch AC.
Or if you have any other ideas that might be more suitable, that would also be welcomed advice!
What do you think?
Thanks!
-Nico
