At The Core Design Challenge
  • At The Core Design Challenge
Blog At The Core Design Challenge: Day 1, debugging through text/messages with "printf" on serial terminal (free ansi c header file).
Join At The Core Design Challenge to participate - click to join for free!
  • Author Author: Digimorf
  • Date Created: 28 Feb 2023 5:12 PM Date Created
  • Views 2221 views
  • Likes 10 likes
  • Comments 6 comments
  • infineon
  • c
  • header
  • PSoCTm︎ 62 MCU
  • element14
  • escape
  • ansi
  • uart
  • serial
Digimorf
Digimorf
28 Feb 2023
I have worked with the examples provided with ModusToolbox and everything works perfectly. I immediately have seen the use of
cy_retarget_io.h
that is used also for targeting the standard IO "printf" function to the serial port. So, as my "best wishes" for you all with the "At the Core Design Challenge", I have written a handful header file that contains the ANSI Escape sequences to use with the serial port and a serial terminal like Tera Term.
I am sharing this file with you.
Fullscreen ansi_escape.txt Download
  * At The Core Design Challenge, 2023
  * File Name          : ansi_escape.h
  * Description        : This file of definitions
  * Created on         : Feb 28, 2023
  * Author             : Francesco De Simone, Digimorf
#ifndef ANSI_ESCAPE_H_
#define ANSI_ESCAPE_H_
#ifdef __cplusplus
 extern "C" {
#endif
// Definitions.
 // ASCII CHARACTERS
 #define ASCII_NULL          0x00 // Null Character
 #define ASCII_BS            0x08 // Backspace
 #define ASCII_TAB           0x09 // Tab
 #define ASCII_LF            0x0A // Line Feed
 #define ASCII_CR            0x0D // Carriage Return
 #define ASCII_ESC           0x1B // Escape
 #define ASCII_SPACE         0x20 // Space
 #define ASCII_A             ('A')
 #define ASCII_L             ('L')
 #define ASCII_Z             ('Z')
 #define ASCII_a             ('a')
 #define ASCII_z             ('z')
 #define ASCII_0             ('0')
 #define ASCII_9             ('9')
 #define ASCII_Q             ('Q')
 #define ASCII_AT            ('@')
 #define ASCII_SLASH         ('/')
 #define ASCII_COLON         (':')
 #define ASCII_DASH          ('-')
 #define ASCII_HASH          ('#')
 #define ASCII_DELETE        0x7F // Tab
 #define CURSOR_NEWLINE      "\r\n"
 // VT100 ESCAPE SEQUENCES //////////////////////////////////////////////////////
 // Device Status
 // The following codes are used for reporting terminal/display settings, and vary depending on the implementation:
 // Requests a Report Device Code response from the device.
 #define QUERY_DEVICE_CODE                "\x1b[c"
 // Generated by the device in response to Query Device Code request.
 #define REPORT_DEVICE_CODE               "\x1b[{code}0c"
 // Requests a Report Device Status response from the device.
 #define QUERY_DEVICE_STATUS              "\x1b[5n"
 // Generated by the device in response to a Query Device Status request; indicates that device is functioning correctly.
 #define REPORT_DEVICE_OK                 "\x1b[0n"
 // Generated by the device in response to a Query Device Status request; indicates that device is functioning improperly.
 #define REPORT_DEVICE_FAILURE            "\x1b[3n"
 // Requests a Report Cursor Position response from the device.
 #define QUERY_CURSOR_POSITION            "\x1b[6n"
 // Generated by the device in response to a Query Cursor Position request; reports current cursor position.
 #define REPORT_CURSOR_POSITION           "\x1b[%d;%dR"
 // Terminal Setup
 // The h and l codes are used for setting terminal/display mode, and vary depending on the implementation. Line Wrap is one of the few setup codes that tend to be used consistently:
 // Reset all terminal settings to default.
 #define RESET_DEVICE                     "\x1b\x63"
 // Text wraps to next line if longer than the length of the display area.
 #define ENABLE_LINE_WRAP                 "\x1b[7h"
 // Disables line wrapping.
 #define DISABLE_LINE_WRAP                "\x1b[7l"
 // Fonts
 // Some terminals support multiple fonts: normal/bold, swiss/italic, etc. There are a variety of special codes for certain terminals; the following are fairly standard:
 // Set default font.
 #define FONT_SET_G0                      "\x1b("
 // Set alternate font.
 #define FONT_SET_G1                      "\x1b)"
 // Gfx mode on.
 #define FONT_GFX_ON                      "\x1b(0" // DEC special graphics table as G0
 // Gfx mode off.
 #define FONT_GFX_OFF                     "\x1b(B" // ASCII table as G0
 // Cursor Control
 // Sets the cursor position where subsequent text will begin.
 // If no row/column parameters are provided (ie. "\x1b[H), the cursor will move
 // to the home position, at the upper left of the screen.
 #define CURSOR_HOME                      "\x1b[\x48"
 #define CURSOR_SET                       "\x1b[%d;%d\x48"
 // Moves the cursor up by COUNT rows; the default count is 1.
 #define CURSOR_UP                        "\x1b[%dA"
 // Moves the cursor down by COUNT rows; the default count is 1.
 #define CURSOR_DOWN                      "\x1b[%dB"
 //Moves the cursor forward by COUNT columns; the default count is 1.
 #define CURSOR_FORWARD                   "\x1b[%dC"
 // Moves the cursor backward by COUNT columns; the default count is 1.
 #define CURSOR_BACKWARD                  "\x1b[%luD"
 // Identical to Cursor Home.
 #define FORCE_CURSOR_POSITION            "\x1b[%d;%d\x66"
 // Save current cursor position.
 #define SAVE_CURSOR                      "\x1b[s"
 // Restores cursor position after a Save Cursor.
 #define UNSAVE_CURSOR                    "\x1b[u"
 #define SAVE_CURSOR_AND_ATTRS            "\x1b\x37"
 #define RESTORE_CURSOR_AND_ATTRS         "\x1b\x38"
 // Hide the cursor.
 #define CURSOR_OFF                       "\x1b[?25l"
 // Show the cursor.
 #define CURSOR_ON                        "\x1b[?25h"
 // Scrolling
 // Enable scrolling for entire display.
 #define SCROLL_SCREEN                    "\x1b[r"
 // Enable scrolling from row {start} to row {end}.
 #define SCROLL_SCREEN_AREA               "\x1b[%d;%d\x72"
 // Scroll display down one line.
 #define SCROLL_DOWN                      "\x1bD"
 // Scroll display up one line.
 #define SCROLL_UP                        "\x1bM"
 // Tab Control
 // Sets a tab at the current position.
 #define SET_TAB                          "\x1b\x48"
 //Clears tab at the current position.
 #define CLEAR_TAB                        "\x1b[g"
 // Clears all tabs.
 #define CLEAR_ALL_TABS                   "\x1b[3g"
 // Erasing Text
 // Erases from the current cursor position to the end of the current line.
 #define ERASE_END_OF_LINE                "\x1b[K"
 // Erases from the current cursor position to the start of the current line.
 #define ERASE_START_OF_LINE              "\x1b[1K"
 // Erases the entire current line.
 #define ERASE_LINE                       "\x1b[2K"
 // Erases the screen from the current line down to the bottom of the screen.
 #define ERASE_DOWN                       "\x1b[J"
 // Erases the screen from the current line up to the top of the screen.
 #define ERASE_UP                         "\x1b[1J"
 // Erases the screen with the background colour and moves the cursor to home.
 #define ERASE_SCREEN                     "\x1b[2J"
 // Printing
 // Some terminals support local printing:
 // Print the current screen.
 #define PRINT_SCREEN                     "\x1b[i"
 // Print the current line.
 #define PRINT_LINE                       "\x1b[1i"
 // Disable log.
 #define STOP_PRINT_LOG                   "\x1b[4i"
 // Start log; all received text is echoed to a printer.
 #define START_PRINT_LOG                  "\x1b[5i"
 //Define Key
 // Associates a string of text to a keyboard key. {key} indicates the key by its ASCII value in decimal.
 #define SET_KEY_DEFINITION               "\x1b[%d;\"%s\"p"
 // Set Display Attributes
 // Set Attribute Mode   "\x1b[{attr1};...;{attrn}m
 // Sets multiple display attribute settings. The following lists standard attributes:
 #define ATTR_RESET_ALL_ATTRIBUTES          0
 #define ATTR_BRIGHT                        1
 #define ATTR_DIM                           2
 #define ATTR_UNDERSCORE                    4
 #define ATTR_BLINK                         5
 #define ATTR_HIDDEN                        8
 #define ATTR_REVERSE                       7
 // Foreground Colors.
 #define ATTR_COLOR_FG_Red                 31
 #define ATTR_COLOR_FG_Green               32
 #define ATTR_COLOR_FG_Black               30
 #define ATTR_COLOR_FG_Yellow              33
 #define ATTR_COLOR_FG_Blue                34
 #define ATTR_COLOR_FG_Magenta             35
 #define ATTR_COLOR_FG_Cyan                36
 #define ATTR_COLOR_FG_White               37
 // Background Colors.
 #define ATTR_COLOR_BG_Black               40
 #define ATTR_COLOR_BG_Red                 41
 #define ATTR_COLOR_BG_Green               42
 #define ATTR_COLOR_BG_Yellow
 #define ATTR_COLOR_BG_Blue                44
 #define ATTR_COLOR_BG_Magenta             45
 #define ATTR_COLOR_BG_Cyan                46
 #define ATTR_COLOR_BG_White               47
 // 256 indexed colors.
 // https://robotmoon.com/256-colors/
 #define ATTR_COLOR_256_BG                 "\x1B[48;5;%d\x6d"
 #define ATTR_COLOR_256_FG                 "\x1B[38;5;%d\x6d"
 #define ANSI_COLOR_256_FGBG               "\x1B[38;5;%d\x6d\x1B[48;5;%d\x6d"
 #define ANSI_PIXEL_256_FGBG               ANSI_COLOR_256_FGBG
 // RGB colors.
 #define ATTR_COLOR_RGB_BG                 "\x1B[48;2;%d;%d;%x6d"
 #define ATTR_COLOR_RGB_FG                 "\x1B[38;2;%d;%d;%x6d"
// Functions.
#ifdef __cplusplus
#endif
#endif // ANSI_ESCAPE_H_
Its use is very simple and as an example, you can include it in your "Hello world" code like the following:
    #include "ansi_escape.h"
    printf(ANSI_COLOR_256_FGBG, 195, 17);
    printf(ERASE_SCREEN CURSOR_HOME);
    printf(ANSI_COLOR_256_FGBG, 195, 19);
    printf(" ************************* " CURSOR_NEWLINE
           " HAL: Hello World! Example " CURSOR_NEWLINE
           " ************************* " CURSOR_NEWLINE CURSOR_NEWLINE);
    printf(ANSI_COLOR_256_FGBG, 15, 17);
    printf("Hello World!!!" CURSOR_NEWLINE CURSOR_NEWLINE);
    printf(ANSI_COLOR_256_FGBG, 7, 17);
    printf("For more projects, "
           "visit our code examples repositories:" CURSOR_NEWLINE CURSOR_NEWLINE);
    printf(ANSI_COLOR_256_FGBG, 208, 17);
    printf("https://github.com/Infineon/"
           "Code-Examples-for-ModusToolbox-Software" CURSOR_NEWLINE CURSOR_NEWLINE);
    /* Initialize timer to toggle the LED */
    timer_init();
    printf("Press ");
    printf(ATTR_COLOR_256_FG, 50);
    printf("'Enter'");
    printf(ATTR_COLOR_256_FG, 7);
    printf(" key to pause or "
           "resume blinking the user LED"  CURSOR_NEWLINE CURSOR_NEWLINE);
Ansi escape sequence
Keep up the good work!
Francesco.
  • Sudeep AJ
    Sudeep AJ over 3 years ago +1
    Can this work on Putty Serial Terminal as well?
  • Digimorf
    Digimorf over 3 years ago in reply to Sudeep AJ
    It should since the escape sequences are standard. But if you want to use for example 256 colors you have to set the terminal emulation to Xterm for example. But feel free to use it and try it.
  • Sudeep AJ
  • Digimorf
    Digimorf over 3 years ago in reply to misaz
    Thanks for the suggestion, I will Relaxed️
  • Digimorf
    Yep, I saw, very useful. That's why I thought to group the escape sequences.
  • misaz
    misaz over 3 years ago in reply to misaz
    If you are interested in more details, then you can see implemntation at Github: https://github.com/Infineon/retarget-io/blob/master/cy_retarget_io.c or you find the same file somewhere in mtb_shared folder.
