BeagleBone Black Radio Challenge
  • BeagleBone Black Radio Challenge
Blog Beaglebone Black Radio challenge - First step(setting up SDR)
  • Author Author: Nitin_Bhaskar
  • Date Created: 16 Feb 2014 12:57 PM Date Created
  • Views 1683 views
  • beaglebone_black
  • sdr
  • beaglebone_black_radio
Nitin_Bhaskar
Nitin_Bhaskar
16 Feb 2014
Thanks element14 for selecting my design for Beaglebone Black Radio Challenge. I own a Beaglebone(first generation) so i have some prior experience in handling this new beauty(BBB).
My project aims in designing a radio using SDR and internet. The radio's interface(GUI) shall be Qt/GTK based. Provision of searching, storing and recording of channel shall be added. The audio output is using a USB sound card. The initial step is make RTL_SDR talk to Beaglebone Black.
Building rtl-sdr software
First, install cmake and libusb on Beaglebone by running
opkg install cmake
opkg install libusb*dev
Check out the rtl-sdr source and build it as described below,
git clone git://git.osmocom.org/rtl-sdr.git
cd rtl-sdr/
mkdir build
cd build
cmake ../
make
sudo make install
This completes the installation. Now its time to test it by running
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib rtl_test -t
Below is output i  got,
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000001
Using device 0: Generic RTL2832U OEM
Found Rafael Micro R820T tuner
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
Sampling at 2048000 S/s.
No E4000 tuner found, aborting.
Success!!!!!
My next step would be to get usb audio to work. Looks like I have to disable HDMI output for this.
    shabaz over 12 years ago +1
    Hi Nitin, Great stuff! And glad you're documenting it step-by-step. Looking forward to trying this out too. I've only tried the SDR dongle on Windows so far. (by the way a carriage-return is missing before…
  • Nitin_Bhaskar
    Nitin_Bhaskar over 12 years ago in reply to onebeartoe +1
    Hi Roberto, My next post will be on that!!!! -Nitin
    Hi Nitin,
    (by the way a carriage-return is missing before "rtl_test -t", so you might want to edit that).
    I think the USB audio should work just fine as soon as you plug in the USB soundcard and then direct the audio to USB soundcard instead of HDMI, depending on the software application (default may still be HDMI, not sure). See here for some old notes on this, to know what the name of the USB soundcard device may be.
  • Nitin_Bhaskar
    Nitin_Bhaskar over 12 years ago in reply to shabaz
    Hi Shabaz,
    Thanks for your quick reply image.  "LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib rtl_test -t" is one single command. Regarding USB audio, BBB recognizes the connected device but when i play an audio file, no output on headphones. I shall try out instructions mentioned in your post. Thanks image
  • Nitin_Bhaskar
    Hi Shabaz,
