Blog Bluetooth Unleashed : AAPSAD #9 : Light and Ventilation
  • Author Author: sakthi.1260
  • Date Created: 30 Jun 2018 2:01 PM Date Created
  • Views 1437 views
  • Comments 7 comments
sakthi.1260
sakthi.1260
30 Jun 2018
Hello guys,
On the last update we added the room freshener. Soldering part is done.
Things to be done to complete the challenge:
1) Ventilation & Lighting
2) Bluetooth Communication between the Arduino and Raspberry Pi
3) UI design (I've never worked on UI, but I'm spending time over it) and program integration
This week on Bluetooth unleashed, we are gonna add a relay module and test it.
I'm strictly not allowed to keep my hands on the building wiring, since the power outage we caused last time.
Somehow I've managed and got permission to test it for a single day and I'm gonna save it for my final demonstration.
A simple connection nothing much, 2 digital pins drive the relays, on addition I've attached a light sensor to analog pin A0.
This light sensor helps to switch on the light under low light condition while running on the automatic mode and DHT11 provides the room temperature.
Yep I've planned both emotion based and manual control and its time to complete the Arduino program.
#include <TroykaDHT.h>
#define ROOM_SUM 11
#define ROOM_CIT 12
#define HUMIDIFIER 9
#define FAN 4
#define LIGHT 5
#define LIGHT_SENSE A0
void freshner (int fresh)
{digitalWrite(fresh,HIGH);
 delay(750);
 digitalWrite(fresh,LOW);
DHT dht(10, DHT11);
void setup()
  pinMode(HUMIDIFIER, OUTPUT);
  pinMode(ROOM_SUM, OUTPUT);
  pinMode(ROOM_CIT, OUTPUT);
  pinMode(FAN, OUTPUT);
  pinMode(LIGHT, OUTPUT);
  digitalWrite(FAN,HIGH);
  digitalWrite(LIGHT,HIGH);
  Serial.begin(9600);
  dht.begin();
void loop()
{ digitalWrite(HUMIDIFIER,LOW);
  dht.read();
  delay(100);
  int hum = dht.getHumidity();
  float temperature = dht.getTemperatureC();
  char c = Serial.read();
  int lux = analogRead(LIGHT_SENSE);
  switch(c){
     case 'a' : //Auto
      if (lux < 100)
          digitalWrite(LIGHT,LOW);
      break;
     case 'b': //ANGER
         if (hum<80)
              digitalWrite(HUMIDIFIER,HIGH);
         if (temperature>26)
              digitalWrite(FAN,LOW);
         freshner(ROOM_CIT);
         break;
      case 'c':             //SAD
        if (hum<60)
        if (temperature>26)
        freshner(ROOM_SUM);
        break;
       case 'd':             //JOY
         if (hum<60)
         if (temperature>26)
         freshner(ROOM_CIT);
         break;
       case 'f':
          break;
       case 'g':
          break;
       case 'h':
          break;
       case 'i':
          break;
Since the Bluetooth part is on progress I ain't providing the complete code in this post.
Here's a sneak peek of the UI, its my first attempt with GUIs kindly bear with me!
Cheers,
Sakthi
    mcb1 over 8 years ago +3
    I'm strictly not allowed to keep my hands on the building wiring, since the power outage we caused last time. Please tell me that all the appropriate Electrical Safety requirements are going to be shown…
    genebren over 8 years ago +1
    Nice update on your design challenge project. It looks like a lot of things are coming to together. Your almost there! Keep up the good work. Gene
    genebren over 8 years ago in reply to mcb1 +1
    What a great safety resource. These links are invaluable. Gene
  • sakthi.1260
    sakthi.1260 over 8 years ago in reply to mcb1
    Thanks Mark,
    Those were really useful, took sometime to go through the links. I'll try to find something safe or make sure the unsafe part is not on the demo video.
    Cheers image
    mcb1 over 8 years ago in reply to genebren
    It is good to know that there are monitors in place here to help and advise those who need help
    haha ... we simply decided one day that it was our "chosen path" .... image
    Feel free to add me or peter into the conversation.
    I'm pretty sure that there are others ...  three-phase perhaps
    Again, sage advice.  Having worked on high voltage systems (mains and above) I have learned a lot about safe practices.  I do cringe when I hear of beginners jumping in and playing at the 'main' voltages level.  It is good to know that there are monitors in place here to help and advise those who need help.
    Safety first, second, third.... and so on.
    Gene
    Thanks ... we had some others somewhere.
    We've had a few 'unsafe' mains control posts here on element14 but we've been able to persuade the poster to modify or hide the bits that are unsafe.
    While the internet is full of dubious methods, there is no place for unsafe practices to be here.
    Those alternative controls linked above are safe, and in many cases cheaper than the alternative, hence we like promoting them.
    What most people miss is the isolation between the Mains and the low voltage control side.
    Many of the cheap asian sourced relay boards don't have the pcb board cut to increase the isolation gap and stop tracking.
    While the opto-coupled boards are close, they still share the same power supply, so they aren't fully isolated from the mains.
    Gene
