Blog Bluetooth Unleashed : AAPSAD #9 : Light and Ventilation
  • Author Author: sakthi.1260
  • Date Created: 30 Jun 2018 2:01 PM Date Created
  • Views 1438 views
  • Comments 7 comments
sakthi.1260
sakthi.1260
30 Jun 2018
Hello guys,
On the last update we added the room freshener. Soldering part is done.
Things to be done to complete the challenge:
1) Ventilation & Lighting
2) Bluetooth Communication between the Arduino and Raspberry Pi
3) UI design (I've never worked on UI, but I'm spending time over it) and program integration
This week on Bluetooth unleashed, we are gonna add a relay module and test it.
I'm strictly not allowed to keep my hands on the building wiring, since the power outage we caused last time.
Somehow I've managed and got permission to test it for a single day and I'm gonna save it for my final demonstration.
A simple connection nothing much, 2 digital pins drive the relays, on addition I've attached a light sensor to analog pin A0.
This light sensor helps to switch on the light under low light condition while running on the automatic mode and DHT11 provides the room temperature.
Yep I've planned both emotion based and manual control and its time to complete the Arduino program.
#include <TroykaDHT.h>
#define ROOM_SUM 11
#define ROOM_CIT 12
#define HUMIDIFIER 9
#define FAN 4
#define LIGHT 5
#define LIGHT_SENSE A0
void freshner (int fresh)
{digitalWrite(fresh,HIGH);
 delay(750);
 digitalWrite(fresh,LOW);
DHT dht(10, DHT11);
void setup()
  pinMode(HUMIDIFIER, OUTPUT);
  pinMode(ROOM_SUM, OUTPUT);
  pinMode(ROOM_CIT, OUTPUT);
  pinMode(FAN, OUTPUT);
  pinMode(LIGHT, OUTPUT);
  digitalWrite(FAN,HIGH);
  digitalWrite(LIGHT,HIGH);
  Serial.begin(9600);
  dht.begin();
void loop()
{ digitalWrite(HUMIDIFIER,LOW);
  dht.read();
  delay(100);
  int hum = dht.getHumidity();
  float temperature = dht.getTemperatureC();
  char c = Serial.read();
  int lux = analogRead(LIGHT_SENSE);
  switch(c){
     case 'a' : //Auto
      if (lux < 100)
          digitalWrite(LIGHT,LOW);
      break;
     case 'b': //ANGER
         if (hum<80)
              digitalWrite(HUMIDIFIER,HIGH);
         if (temperature>26)
              digitalWrite(FAN,LOW);
         freshner(ROOM_CIT);
         break;
      case 'c':             //SAD
        if (hum<60)
        if (temperature>26)
        freshner(ROOM_SUM);
        break;
       case 'd':             //JOY
         if (hum<60)
         if (temperature>26)
         freshner(ROOM_CIT);
         break;
       case 'f':
          break;
       case 'g':
          break;
       case 'h':
          break;
       case 'i':
          break;
Since the Bluetooth part is on progress I ain't providing the complete code in this post.
Here's a sneak peek of the UI, its my first attempt with GUIs kindly bear with me!
Cheers,
Sakthi
    mcb1 over 8 years ago +3
    I'm strictly not allowed to keep my hands on the building wiring, since the power outage we caused last time. Please tell me that all the appropriate Electrical Safety requirements are going to be shown…
    genebren over 8 years ago +1
    Nice update on your design challenge project. It looks like a lot of things are coming to together. Your almost there! Keep up the good work. Gene
    genebren over 8 years ago in reply to mcb1 +1
    What a great safety resource. These links are invaluable. Gene
    Gene
    Gene
