Design For A Cause 2021
  • Design For A Cause 2021
Blog Design for a Cause 2021 - Robotic Hand (Blog #8) - Code update
  • Author Author: dwinhold
  • Date Created: 3 Jun 2021 12:39 AM Date Created
  • Views 573 views
  • design for a cause 2021
  • dwinhold
  • robotic hand
dwinhold
dwinhold
3 Jun 2021
I wanted to post the updated code I am now using for the robotic hand. This code works 100% better, it calibrates the signal for each finger for more precise movement.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "EMGFilters.h"
#include <Servo.h>
#define TIMING_DEBUG 1
#define SensorPin A0 // input pin number
EMGFilters myFilter;
SAMPLE_FREQUENCY sampleRate = SAMPLE_FREQ_500HZ;
NOTCH_FREQUENCY humFreq = NOTCH_FREQ_60HZ;
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
static int Threshold = 50;
const int stepsPer = 200;
int envlope = 0;
const int ledPin = 13;
unsigned long timeStamp;
unsigned long timeBudget;
int sensorValue = 0;         // the sensor value
int fingerValue = 0;
int a = 400;
int b = 0;
int x = 0;
int y = 0;
int calB = 0;
int calR = 0;
int calM = 0;
int calI = 0;
int calT = 0;
float calMod = 1.1; //Add a 10% calibration modifier
float calModMinus = 0.9; //Subtract 10% calibration Modifier
void setup(){
  myFilter.init(sampleRate, humFreq, true, true, true);
  Serial.begin(115200);
  timeStamp = micros();
  myservo1.attach(2);
  myservo1.attach(3);
  myservo1.attach(4);
  myservo1.attach(5);
  myservo1.attach(6);
  b = 0;
  x = 0;
  Serial.println("Calibrate fingers in 2 seconds");
  delay(1000);
  Serial.println("Calibrate Baby finger");
  delay(250);
  digitalWrite(ledPin, HIGH);
  delay(250);
  digitalWrite(ledPin, LOW);
  delay(250);
  delay(250);
    while (millis() < 15000) { //Calibrate Baby Finger
    int Value = analogRead(SensorPin);
    // filter processing
    int DataAfterFilter = myFilter.update(Value);
    int envlope = (sq(DataAfterFilter));
    x = envlope;
    calB = calB + x;
    b = b + 1;
  calB = calB / b; //Average Baby Finger Readings
  Serial.println(calB); //Show calibration Reading
  delay(250);
  delay(250);
  delay(250);
  Serial.println("Calibrate Ring finger");
  delay(250);
  delay(250);
  delay(250);
  delay(250);
    b = 0;
   while (millis() < 15000) { //Calibrate Ring Finger
    x = envlope;
    calR = calR + x;
    b = b + 1;
  calR = calR / b; //Average Ring Finger Readings
  Serial.println(calR); //Show calibration Reading
  delay(250);
  delay(250);
  delay(250);
  Serial.println("Calibrate Middle finger");
  delay(250);
  delay(250);
  delay(250);
  delay(250);
   b = 0;
   while (millis() < 15000) { //Calibrate Middle Finger
    x = envlope;
    calM = calM + x;
    b = b + 1;
  calM = calM / b; //Average Middle Finger Readings
  Serial.println(calM); //Show calibration Reading
  delay(250);
  delay(250);
  delay(250);
  Serial.println("Calibrate Index finger");
  delay(250);
  delay(250);
  delay(250);
  delay(250);
    b = 0;
    while (millis() < 15000) { //Calibrate Index Finger
    x = envlope;
    calI = calI + x;
    b = b + 1;
  calI = calI / b; //Average Index Finger Readings
  Serial.println(calI); //Show calibration Reading
  delay(250);
  delay(250);
  delay(250);
  Serial.println("Calibrate Thumb finger");
  delay(250);
  delay(250);
  delay(250);
  delay(250);
    b = 0;
    while (millis() < 15000) {  //Calibrate Thumb
    x = envlope;
    calT = calT + x;
    b = b + 1;
  calT = calT / b; //Average Thumb Readings
  Serial.println(calT); //Show calibration Reading
void loop() {
       if (calB > envlope * calModMinus && calB < envlope * calMod){ //Baby finger
       servo1(); //Goto function servo1
       Serial.println("Small");
       Serial.println(envlope);
       delay(100);
       if (calR > envlope * calModMinus && calR < envlope * calMod){ //Ring Finger
       servo2(); //Goto function servo2
       Serial.println("Ring");
       delay(100);
       if (calM > envlope * calModMinus && calM < envlope * calMod){ //Middle Finger
       servo3(); //Goto function servo3
       Serial.println("Middle");
       delay(100);
       if (calI > envlope * calModMinus && calI < envlope * calMod){ //Index Finger
       servo4(); //Goto function servo4
       Serial.println("Index");
       delay(100);
       if (calT > envlope * calModMinus && calT < envlope * calMod){ //Thumb
       servo5(); //Goto function servo5
       Serial.println("Thumb");
       delay(100);
     delay(100);
void servo1(){
  myservo1.attach(2); //Power to servo
  delay(15); //Short delay
  myservo1.write(180); //Turn servo 180°
  delay(1000); //Delay 1 second
  myservo1.write(0); //Return servo to 0°
  myservo1.detach(); //Power off to servo
void servo2(){
  myservo2.attach(3);
  delay(15);
  myservo2.write(180);
  delay(1000);
  myservo2.write(0);
  delay(1000);
  myservo2.detach();
void servo3(){
  myservo3.attach(4);
  delay(15);
  myservo3.write(180);
  delay(1000);
  myservo3.write(0);
  delay(1000);
  myservo3.detach();
void servo4(){
  myservo4.attach(5);
  delay(15);
  myservo4.write(180);
  delay(1000);
  myservo4.write(0);
  delay(1000);
  myservo4.detach();
void servo5(){
  myservo5.attach(6);
  delay(15);
  myservo5.write(180);
  delay(1000);
  myservo5.write(0);
  delay(1000);
  myservo5.detach();
Thank you for following!!
Dale Winhold
