Blog Design for a Cause - The Ultimate Smart Trike Design Blog 1 of 4
  • Author Author: Sean_Miller
  • Date Created: 13 Jul 2018 4:58 PM Date Created
  • Views 3583 views
  • Likes 14 likes
  • Comments 10 comments
  • raising awesome
  • lcd display
  • accessibility_projects
  • e14presents_raisingawesome
  • ardexpert
  • vcp_acause
  • mkr1000
  • ultrasonic proximity sensor
Sean_Miller
Sean_Miller
13 Jul 2018
Add a Motor to your Bike with Arduino
element14 Presents  | Raising Awesome's VCP Profile    |  Project Videos
Jump to Blog 2:Design for a Cause - The Ultimate Smart Trike Design Blog 2 of 4
INTRODUCTION
We are Sean and Connor Miller from the YouTube Channel Raising Awesome.  I've had a career of diverse roles spawned from an engineering degree and 13 year old Connor - well, I hope he saves the world some day.  We have partnered with Element14.com for the up coming Design for a Cause Challenge.
We recently worked with Element14.com and The Ben Heck show for a Design for a Cause assistive technology project, the Clock Crane.  It is designed to assist taking items between floors for someone who cannot manage stairs with two handed objects.  In our lives, we all have someone we care about that was either born with such an impairment or, as time went on, found themselves with such a physical challenge.  With what is truly a simple application of technology, one's day and thoughts can be stepped closer to the comfort that others enjoy.
For our next project, we aren't competing in the Design for a Cause challenge, but we are definitely participating.  Our goal is to help inspire others to join the challenge or embark on an assistive technology build of their own - or just find a way to make their ideas come to life that could make the world a better place.  Specifically for this build, we hope to showcase the advantage the MKR1000 IoT kit and the skills you learn when prototyping with it can have when coupled to mechanical components.
So, here's our story...when Connor was two years old, his mom (Brenda) was diagnosed with Multiple Sclerosis (MS).  Per current science, MS is considered an auto immune disease where one's own immune system attacks the myelin sheath of the nerves in the brain and spinal cord resulting in what Makers would call "knicks in the wire insulation".  In turn, the nervous system has "shorts to ground".  As time goes on, it typically results in impairment requiring a cane or wheel chair, high fatigue, and numbing pain similar to when one gets the "needles" from their leg falling asleep.
The diagnosis of MS starts with motor skill tests that isolate the issue.  Once narrowed down, the diagnosis moves to an MRI and spinal tap.  The MRI shows lighted spots (aka legions) on the brain.  The spinal fluid shows a higher amount of certain proteins.  For Brenda, although there were possibly signs leading up to it, the symptoms escalated suddenly on a trip the took across the God's Country of West Virginia (for you Fallout fans).  The major symptoms subsided slightly so that she no long required a cane until a year ago when they came back worse than ever.  Having moved to east of St. Louis where there are over 80 miles of paved rail trail for walking and biking, this suddenly put a damper on our favorite part of this location.  As Makers, we weren't just going to give up riding.  So, our Design for a Cause project was born.
PROJECT DESIGN
In this assistive technology project to take us back to the trails, we need to establish a means of cycling that addresses the following:
  • poor balance to keep the bike in one's own lane
  • weak grip with the left hand to squeeze the bike brake
  • inability to stand to "torque" up hills
  • inability to step over the center bar to mount the bike
  • general quick fatigue due to left leg pain
To pull this off, we will apply the following assistive technology:
  • Trade in the 2 wheeled bike for a 3 wheeled, low center bar trike
  • 36V 500 RPM motor geared for 11 mph
  • 36V motor controller and thumb throttle
  • (3) 12V batteries
  • MKR1000 IoT kit
  • Additional Design for a Cause Challenge Components
  • ESP8266
Key features of this Smart Trike will be:
  • Motor interlock due to over tilt
  • Motor interlock when either brake is applied
  • Motor interlock for objects too close
  • Motor interlock if stopped peddling
  • Power Assist braking
  • LCD display of speed, distance, travel time, and interlock status information
  • Garage door opener/closer
  • Data logging for speed, distance, travel time, interlock hits with identifying reason, and tilt
  • Bike Security Alarm
  • Retro Paperboy Arcade Portable - just kidding - that's for a future winter time build
BUILD NOTES
Logic Levels:
    • The Ultrasonic Proximity Sensor and the LCD both will need 5V to function properly.  The MKR1000 runs on a 3.3V logic level.  So, any inputs to the MKR1000 need to be 3.3V.
    • On the Ultrasonic Proximity Sensor, you need to put a voltage divider or level shifter on the echo pin.  I used a 680 ohm and 1K ohm voltage divider circuit which took it down to 3.02V on the oscilloscope.
    • On the LCD, the R/W pin (#5) can just be taken to ground.
          SD Card Shield Pinouts:
    • The SD Card shield will use 4 pins.  I'm sure there can be sharing of the pins if one takes some coding precautions, but if you wants to avoid them altogether, here they are:  D4, D8, D9, D10.
CLOSING COMMENTS
We appreciate Element14 allowing us to "give back" in our own unique way.  We hope you find our series of four (4) videos and blogs fun, educational, and inspiring.  If you have interest in other skill sets, such as watching Connor learn to weld so he can make the motor mount for this project, check us out on the Raising Awesome channel.  It is the chronicle of Connor's life lessons and life skills development from 9 to 18 where he is learning and sharing how to do every practical skill on our modern planet.
-Sean and Connor
  • Sean_Miller
    Sean_Miller over 8 years ago in reply to jkutzsch +3
    Great question. This trike attracted me primarily because I saw about 4" of free keyed shaft exposed in the back and a platform that I could install a motor on. If I were not to motorize and MKR1000 it…
  • Sean_Miller
    John, we have some really good Crash Test Dummy footage for you on this style of trike! I just sent our Episode 2 raw video to the element14 team for editing. We were lucky and caught some real world physics…
  • 14rhb
    14rhb over 8 years ago +2
    Hi Sean and Connor, Nice one. I look forward to seeing how this progresses and hearing what Brenda makes of it. Good luck. Rod
  • Sean_Miller
    Sean_Miller over 8 years ago in reply to jomoenginer
    Thanks for the comment.  We are very much enjoying the build.  We've already broadened our past experiences by diving into hall effect sensors to be used for the speed and crank sensors.  In the past, I've used reed switches, but the hall effect sensors should be much more reliable.
    The mechanical side is coming along well, too.  We found that the trike as it came just didn't have good stopping power.  It had an old school band brake on it that was also taking up too much room at the center of the drive train.  Now that we've loaded it up with three 12V batteries, it really needs some help stopping.  In our third video, you'll see our solution.
    Again, thanks for the comment!  We hope you enjoy the remaining three videos to come of the next few weeks.
    See ya',
    Sean
  • jomoenginer
    jomoenginer over 8 years ago
    It's great to see you guys collaborate with element14 on this. You guys are certainly no stranger to the site.
    I like the idea of the Smart Trike.  This seems so much more practical than those Shared Scooters that are invading cities around the globe.   I'm sure other folks would be interested in a Trike like this.
    Cheers!
    DAB over 8 years ago
    I like the trike, but it needs a bigger seat for me.
    genebren over 8 years ago
    Great update on your project.  I look forward to following along and see how it turns out.
    Gene
  • 14rhb
    Hi Sean and Connor,
    Good luck.
    Rod
