Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Enchanted Objects Design Challenge - The Lode Stone
  • Author Author: Workshopshed
  • Date Created: 15 Jun 2015 7:51 AM Date Created
  • Views 3738 views
  • Comments 15 comments
  • enchanted_cottage
  • enchanted_objects
Workshopshed
Workshopshed
15 Jun 2015
A trip up the fell
Matilda looked serious, she was dressed in a boiler suit, boots and a hard hat, she was leaning on a pickaxe. "Do you remember that watch my father gave you as a wedding present?", Hans nodded and took it out of his waistcoat pocket. "Put it in the drawer", Matilda commanded "and your reading glasses". Hans put the items in the drawer. "Put on your gear and meet me out front". Hans put on his boiler suit, hat and boots and headed out. He was met by Matilda and Farmer Hogg who was pushing a wheel barrow. "Upt yonder fell", said Farmer Hogg, Hans looked blankly. Farmer Hogg muttered something under his breath and passed a scrap of paper with a hastily drawn map.
As they neared the top of the hill, Matilda brought out a compass and started wandering in circles. Suddenly the compass needle twitched and Matilda smiled. She cleared off the turf and almost immediately hit rock. She donned her safety glasses and raised the pick, thud, thud, thud, sparks, "bingo!" cried Matilda. The ore was shovelled into the barrow and wheeled down the hill to C.Defoe's builder's yard.
Matilda asked Mr Defoe for 4 diametrically magnetised disk magnets and the Golem smashed up the ore and squashed it into a disk under great heat and pressure. "I'll plate them and drop them around in the morning" said Mr Defoe. The next morning the magnets were delivered with instructions to take care not to trap their fingers between two magnets. The diametrically magnetised magnets ensured that Hans and Matilda would remain facing in the right direction.
Diametrically Magnetised Magnets
Magnet Holders
The initial thought was that the magnets could be attached to the mechanism using Sugru, however Matilda realised that this was a rubber compound and would cause friction.
There was a nylon bar that could be machined for a housing but that would be problematic to glue to the base / magnets. So a magnet housing was designed for 3D printing that could be clipped/glued onto the mechanism, ABS rubbing against the wood would run quite smoothly.
Hans and Matilda's platforms were carefully milled by hand so that magnets could be added to those too.
The magnets were test fitted in preparation for a full system test.
Thanks to Eric Styles from First4Magnets for advice on the right type and strength of magnet.
Next: Enchanted Objects Design Challenge - A tale of two bridges
  • element14Dave
    element14Dave over 11 years ago in reply to mcb1 +2
    There was an issue over the weekend, which I have confirmed has been resolved.
    balearicdynamics over 11 years ago +1
    Andy, this is a really great solution Automated movement without touching the original couple. Cheers to Hans & Matilda Enrico
  • gadget.iom
    gadget.iom over 11 years ago +1
    Very nice solution
    mcb1 over 11 years ago
    Looks like a great solution ....
    On minor problem is that there are no images ...just the name of the image and even when you click on it ...nothing.
    Fullscreen contentimage_179208.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    balearicdynamics over 11 years ago in reply to mcb1
    Mark,
    if you refer to the original post there are lot of images... Maybe you (and someone other) didn't see the images. Maybe this depends on a problem that I was notified by the E14 tech support of a server that for a certain period today (4-5 hrs ago) was down? I contacted them as in China it was impossible to see some posts. I suggest that you (and atclark too) try to clear your local cache, I had to do so.
    Enrico
    mcb1 over 11 years ago in reply to Workshopshed
    Clear cache didn't work
    Intersetingly though the info shows the size as 0x0px
    Fullscreen contentimage_179209.html Download
    Thats even worse.
    Some are just a name, others are blank images that occupy the sapce the proper one should ...
  • element14Dave
    mcb1 over 11 years ago in reply to element14Dave
    element14Dave
    Thanks Dave.
    I've just gone back and cleared the cache, but only 1 in 5 pics are visible.
    (I chopped the bottom of the picture)
  • matth2
    matth2 over 11 years ago in reply to mcb1
  • matth2
