Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog The Genie's Day Brightens
  • Author Author: RParkerE
  • Date Created: 22 May 2015 9:12 PM Date Created
  • Views 2727 views
  • Comments 14 comments
  • enchanted_objects
  • mini_automator
RParkerE
RParkerE
22 May 2015
The week was full of rain and clouds for the poor genie all week. Unable to leave his house and make any progress on the things that needed to get done, due to the unfortunate consequences of doing your electrical work in the rain, but today the sun peeked out from behind the clouds and shone with the brightness of 2000-2500 lumen. It was magnificent! However, shortly after its arrival, the clouds took over again . But while the sun was out the genie made headway on his electrical wiring of his sweet new crib. He set the power supply to roughly thirty volts and tested out his lights to see if they worked.
And it worked! How excited the genie was! This was a huge step in the right direction with the build of his new pad. Now all that was needed to be done was wire it all up to his sweet new dimmer and you could call him Xzibit Jr.
WAIT! There is no light!!!! What in the world is going on? No explosions, check. No fire or smoke, check. Then what? The genie checked the voltage coming out and the light intensity and found:
But that doesn’t make sense! 30 Volts in and only a 100th of that out? How could this be? The genie has yet to figure this out, but he will be working diligently over the weekend to figure out a solution!
    mcb1 over 11 years ago in reply to Jan Cumps +3
    Jan Cumps You wouldn't be the first or last to miss something in a post ... You raised a very good pint about the meter though. I wonder if someone who has a working LED can do some checking using a simple…
  • RParkerE
    RParkerE over 11 years ago in reply to mcb1 +3
    I found the culprit and it was much simpler than assumed. I had a poor connection, after I soldered the pins it worked perfectly fine. I am working on my next update now
    Jan Cumps over 11 years ago +2
    The week was full of rain and clouds for the poor genie all week. Unable to leave his house and make any progress on the things that needed to get done, We seem to have the opposite way of working . I…
    Don't forget the heatsink ....
    The frequency and shape of the output signal of the Infineon board may be too hectic for your meter.
    Yes but no light as well ...
    You may wish to try experimenting with a few standard leds and 10v ...rather than destroy your high power one.
    This looks like similar to my 30W RGB version, which even with a single led string at 1/3 power was enough to make you see spots for a while afterward.
    Internet of Holiday Lights RoadTest Plus (suppliment) Part 2
  • RParkerE
    The issue is I am unable to reach the loop method. It gets stuck in the setup method and will loop over a single function in that. I assume the board is not responding because it gets stuck in the while(on != 1) loop which checks if it is responding. I am not sure how to solve this issue.
    mcb1 over 11 years ago in reply to RParkerE
    Can you post your code?
    Please use the >> symbol and choose Syntax Highlighting then C++.
    I'll see if I can duplicate it.
  • RParkerE
    I like simple faults ...
    I see you have posted the next post ...well done.
