Energy Harvesting Design Challenge
  • Energy Harvesting Design Challenge
Blog A Very Compact Guide to Energy Harvesting - Part 008
  • Author Author: COMPACT
  • Date Created: 1 May 2013 10:24 PM Date Created
  • Views 526 views
  • energy_harvesting
  • energy_harvesting_challenge
COMPACT
COMPACT
1 May 2013
Some Interesting Pictures
Here are some pictures of the more interesting energy harvesting signals that I've captured.
    DAB over 13 years ago
    Hi Monte,
    Can I assume that the cymbal and drum signals are from single impulse hits?
         Have you considered setting them up with either falling water or sand to drive the impulses?
    I am also assuming that the printer motors were just given a quick twist.
         Have you considered putting a air capture or motor driver to see how stable the output from the motors changes over various speeds?
         Does the output current/power rise with higher speeds?
    I also assume that the ice block signal is from your thermocouple.
         Have you considered attaching a solar cell to the other side to see how much additional power you can extract from a solar illumination?
    Cool pictures.
  • COMPACT
    COMPACT over 13 years ago in reply to DAB
    Hi Don,
    You're absolutely right.
    The Piezo drum hits requires mighty hits to accomplish signals of this magnitude. Just tapping it produces neglible energy.
    The printer motors produce very stable power. The magnitude of the signal is proportional to is rotational speed.
    From past experiments with Solar it works really well.
    Cheers
    Very Compact
  • COMPACT
    Hi Don,
    Cheers
    Very Compact
