Energy Harvesting Design Challenge
  • Energy Harvesting Design Challenge
Blog A Very Compact Guide to Energy Harvesting - Part 012
  • Author Author: COMPACT
  • Date Created: 15 May 2013 10:32 AM Date Created
  • Views 612 views
  • energy_harvesting
  • energy_harvesting_challenge
COMPACT
COMPACT
15 May 2013
Just Milling about for a Tinny!
I've outline milled out a PCB for the LED Driver.
Here is the result.
I then manually weeded out the unwanted copper with a scapel blade.
After this I then decided to plate the copper and make it silvery.
It now looks like a bought one.
I also have the capability to apply a solder mask but since this is a prototype it wasn't necessary.
    DAB over 13 years ago
    Hi Monte,
    Have you considered using a CNC milling machine to make the board?
    If you did this one by hand, I admire your technique.  That is very good craftsmanship.
    Thanks
    Hi Monte,
    Thanks
  • COMPACT
    COMPACT over 13 years ago in reply to DAB
    Thanks Don,
    I used a CNC machine to mill the outline of the PCB.
    Hand weeding of copper voids preserves my engraving bits and gives a very good result at the expense of my sanity.
    Cheers
    Very Compact
