Energy Harvesting Design Challenge
  • Energy Harvesting Design Challenge
Blog A Very Compact Guide to Energy Harvesting - Part 014
  • Author Author: COMPACT
  • Date Created: 20 May 2013 2:49 AM Date Created
  • Views 981 views
  • energy_harvesting
  • energy_harvesting_challenge
COMPACT
COMPACT
20 May 2013
Getting Smaller
The cordless drill motor is very effective at generating power but its size is is too big to be put into a TV remote control unit.
On my quest for a smaller generator I came across a hand cranked LED torch.
The generator is a very good size. Its winding are made with very fine enamelled copper wire.
The wire is as fine as the wire used for old AM radio bar antennas.
I have added some tap leads to it enabling me to measure its outputs and use it for other purposes.
Here is a snapshot of the output.
It is nowhere near as powerful as the cordless drill motor but it is definitely useable.
Here it is powering the STK3700.
Unlike the cordless drill where a half turn is sufficient to start the STK3700, the LED torch generator (with its LEDs disconnected from the circuit) required about 6 or more cranks.
    DAB over 13 years ago
    Hi Monte,
    The hand crank devices are usually designed for light duty, but they can serve as a starting point to evaluate the energy transfer potential for the type of device in a given application.
    Now all you need is someone willing to crank up the TV or your computer so that you can use it.
    There is probably a good plot for a satire show on energy harvesting somewhere in there.image
    Just a thought,
    Hi Monte,
    Just a thought,
