Experimenting with Gesture Sensors
  • Experimenting with Gesture Sensors
Challenge Blog Experiment with Gesture Sensor Final Music Player - (blog2)
  • Challenge Blog
Join Experimenting with Gesture Sensors to participate - click to join for free!
  • Author Author: asokfair
  • Date Created: 28 Dec 2022 10:41 AM Date Created
  • Views 1437 views
  • Likes 11 likes
  • gesture sensors
  • maxim integrated
  • experimenting with gesture sensors
  • MAX25405EVKIT
asokfair
asokfair
28 Dec 2022
Hi All,
In the previous blog (blog1) i have explained about the over all idea and getting started guide with the sensor. In this blog i have implemented the music control over gesture.
My initial plan is to use DFmini player to play the mp3 file but due to some limitation with time & support for MAX25405EVKIT  i have used PC and python scripting to playing audio.
My setup looks like below, I have used Bluetooth Speaker which is connected to the PC. UART TX, RT P3_1, P3_0 pins connected to serial to USB converter and connected to PC.
Blog Design:
Building the Code:
Initially i thought building the firmware was easy job but due to some github versions , it took more time for me. The blogs from misaz really helpful for me find out the working version of
firmware.
image checkout
Installed pythons & Visual Studio tools helps to build the firmware without any issues.
git checkout 0fdfcf7350896a9c0b57c4a18237677abfe25f1a
Code changes
// Option to implement serial API over UART instead of USB
#define USE_UART_INTERFACE 1
#define UART_BAUD_RATE 115200
After all changes the code works and prints in uart console.
Python Interface:
I used python to read the serial data over com port.  I have made logic to Play/Pause/Next/Previous controls using gesture values.
Working Demo:
The final working demo of video is here. I will be improving the version in the future. Thank you all for the support.
    dougw over 3 years ago
    Congratulations on getting it working.
    DAB over 3 years ago
    Nice build.
