Experimenting with Gesture Sensors
  • Experimenting with Gesture Sensors
Forum If you have a question about the Experimenting with Gesture Sensors competition, kit or anything else, you can also ask it here.
  • Challenge Blog
Join Experimenting with Gesture Sensors to participate - click to join for free!
  • Replies 12 replies
  • Subscribers 43 subscribers
  • Views 2638 views
rscasny
rscasny over 4 years ago
  • rscasny
    rscasny over 4 years ago in reply to rahulkhanna +2
    They will be this week.
  • misaz
    misaz over 4 years ago in reply to rsjawale24 +2
    This description come from Maxim website. https://www.maximintegrated.com/en/products/sensors/MAX25405EVKIT.html I think that this time the kit was not bundled by Element14 but they froward kit packed…
  • misaz
    I did not know about it. If you will not be able find FFSD-08-D , then try any other ribbon cable with 1.27 mm pitch and 2x8 pins. If you buy cable without lock, then pay attention about orientation.
  • me_Cris
    0 me_Cris over 4 years ago
    Hello rscasny ,
    I saw your message by accident, I see you sent it to me 4 days ago, I don't know why I wasn't notified.
    What's up ?
  • rahulkhanna
    0 rahulkhanna over 4 years ago
    Are the results out?
  • rscasny
    0 rscasny over 4 years ago in reply to me_Cris
    This was meant as a general message .
    Randall
  • rscasny
    0 rscasny over 4 years ago in reply to rahulkhanna
  • rsjawale24
    0 rsjawale24 over 4 years ago
    I received the kit today. I just checked the main blog of the contest and I found that the eval kit contains the following -
    However, I only received the power supply, the MAX32620FTHR MCU, interface shield and the MAX25405 sensor board.
    The ribbon cable and the USB cable seem to be missing. Are they supposed to be a part of the contest eval kit?
  • misaz
    0 misaz over 4 years ago in reply to rsjawale24
    This description come from Maxim website. https://www.maximintegrated.com/en/products/sensors/MAX25405EVKIT.html I think that this time the kit was not bundled by Element14 but they froward kit packed by Maxim. All devkits from maxim (which I had worked with) always contained all specified. My MAX25405 kit is still on the way and I am out of home. At Friday/Saturday I will check and write back if my kit contain these cables.
    USB cable should not be issue. It is standard cable. You can find them bundled with many other devices. You most probably have one bundled with your mobile phone. If you dont, then you can get it in almost every store including many non-IT stores.
    With ribbon cable it is more complicated. Accodring to schematics in datasheet, onboard connector is Samtec FTSH-108-01-L-DV-K which mates with Samtec FFSD family. Cables starting with FFSD-08-D should be compatible. Many other 1.27mm pitch ribbon cables may work. Search for FFSD-08-D in your favourite store. Other numbers in code specify length (I recmmend at least 10 inch). For example FFSD-08-D-18.00-01-N which is 18 inch long is currently avalaible at Farnell should work.
  • rsjawale24
    0 rsjawale24 over 4 years ago in reply to misaz
    Hi misaz!
    Thanks you. Yes, USB cable is not an issue. I have plenty of these USB cables. However, the connector cable is something rare. I don't have it with me. I'll go to my local electronics market later this week (it's festival time in India so shops will be closed on wednesday) and they should have it.
    Thank you so much for the help. Awaiting to see your kit contents
  • rsjawale24
    Farnell in India (element14) is only B2B not B2C. They do not ship to customers. So i'll have to rely on the local shops only. Will update here if I get the connector cable by weekend.
  • misaz
    I did not know about it. If you will not be able find FFSD-08-D, then try any other ribbon cable with 1.27 mm pitch and 2x8 pins. If you buy cable without lock, then pay attention about orientation.
  • rscasny
    0 rscasny over 4 years ago in reply to rsjawale24
    We were sent the white box that contained the kit. I don't think we opened them up. The parts list came from the website. You should have gotten the ribbon cable. Let me look into it.
