Experimenting with Inductors
  • Experimenting with Inductors
Documents Experimenting with Inductors: The Challengers
  • Author Author: pchan
  • Date Created: 10 Jan 2020 5:35 PM Date Created
  • Last Updated Last Updated: 13 Jan 2020 4:50 PM
  • Views 1701 views
  • Likes 8 likes
About Competition | Blogging | Example Application | The Prizes | The Judges | Terms & Conditions | The Challengers | In-depth on Inductors with KEMET Video | Inductors & Solenoids Video | The Quiz | Passive Components
Welcome to the Experimenting with Inductors Challengers Page!
Our 'Experimenting with Inductors' Competition, a collaboration/association with KEMET, has now launched.  The 9 chosen challengers will use the inductors from the kit to create or alter a design, showcasing what they have learned about inductors.  They will receive a Challenger Kit for FREE.  If you are not a sponsored challenger but want to join the competition see detail here.
Please join us in congratulating the official sponsored Challengers.  We look forward to reading all your initial blogs introducing your project designs.
Ankur Verma | Donald Lane | F. Yao | Gene Breniman | Huy Mai | Leow Cheah Wei | Miguel Pineiro | Rushiraj Jawale | Sean Miller
ankur608
India
Integrated Design of Buck-Boost Regulator
Synopsis:  I will experiment with the use of inductors in a function prototype of a buck and/or boost regular.
Ankur Verma's project blogs
three-phase
UK
Reflectometer Test Delay Line
Synopsis: I intend to build some inductor / capacitor based delay lines for use with a rotor reflectometer for testing inter-turn faults within generator rotor windings.
Donald Lane's project blogs
fyaocn
China
Inductors in RF Transmitter and Receiver
Synopsis: I will experiment with the functional and performance of inductors using different values on the RF transmitter and receiver circuit.  The idea uses a software defined radio with limited hardware resources on Cortex ARM dev board.
F. Yao's project blogs
genebren
USA
Effects of Inductors on a Boost Regulator Circuit
Synopsis: My experiment will study the parameter effects (e.g., inductance, DC resistance and rated current) in a boost regulator circuit.  I plan to modify an existing design (Walky the Biped Robot - Power pack) to accommodate multiple foot prints for SMD and through hole parts.
Gene Breniman's project blogs
kurst811
USA
RF Energy Harvesting Efficiency with Inductors
Synopsis:  I will experiment with different inductors from the kit and record energy output and create a model to find the optimal inductor for different antennae.
Huy Mai's project blogs
weiwei2
Malaysia
Experimenting via System Simulation and Modeling
Synopsis: I want to do a multi physics modeling and simulation. By doing modeling & simulation, and validating its result against my fabricated simple circuit, I believe I can obtain sufficiently good insights into inductors.
Leow Cheah Wei's project blogs
neuromodulator
Chile
Characterization of Inductors
Synopsis: I would like to build an oil-based temperature chamber that will generate uniform temperature/time curves.  It will characterize the effect of temperature in the inductance and resistance of inductors.
Miguel Pineiro's project blogs
rsjawale24
India
rsjawale24: Inductors Experiment
Synopsis: I will design an experiment using inductors and electronic components, which will verify/prove the Fourier series. It summarizes that continuous time, and periodic signal can be expressed as the sum of harmonics of sinusoidal signal.
Rushiraj Jawale's project blogs
Sean_Miller
USA
Custom Datalogger Power Sources
Synopsis:  I will make power circuits that will take 24V to 12V, 5V, and 3.3V.  This is provide switching power to I2C devices, cameras, etc. so all of this, including the microcontroller, can be on a single PCB.
Sean Miller's project blogs
Interested in joining the Challengers? You can do it as a non-sponsored Challenger! Here's how:
Simply get any of the featured inductors from the kit, integrate them into your project, and post 2 blogs about your design journey in the Experimenting with Inductors Competition (tagging your blogs 'Experimenting with Inductors Competition') and you'll be eligible to win the awesome prizes.
Read full terms & conditions for more details.
Good Luck Everyone!
  • experimenting_with_inductors
  • the challengers
  • experimenting with inductors
  • rsjawale24
    rsjawale24 over 6 years ago +2
    Congratulations to all and best of luck for the competition.
  • jc2048
    jc2048 over 6 years ago +2
    Good selection of projects there. I'm looking forward to following this.
  • COMPACT
    COMPACT over 6 years ago +2
    It's a good time to coil up!
  • Sean_Miller
    Sean_Miller over 6 years ago
    I hope I don't "choke".  image
  • COMPACT
  • jc2048
  • rsjawale24
    Congratulations to all and best of luck for the competition. image
