Experimenting with Single Pair Ethernet
  • Experimenting with Single Pair Ethernet
Forum Technical Support Thread | Experimenting With Single Pair Ethernet
  • News
  • Projects
  • Enroll
Join Experimenting with Single Pair Ethernet to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 34 subscribers
  • Views 799 views
  • molex
  • single pair ethernet
  • experimenting with single pair ethernet
  • spe
JoRatcliffe
JoRatcliffe 9 months ago
Hi Ben5049 , JWx , veluv01 , vmate , how are we doing with the challenge?
There has already been some great discussion on the kit but, as everyone progresses, I thought it might be helpful if I created a dedicated place for discussing any technical challenges you come across or solutions that you discover.
This is also a great place if you have any questions for Molex, the challenger sponsor and provider of much of the kit. You can also contact me directly if you prefer.
To help facilitate discussion, I am sharing below some reference points like the part numbers and order codes as well as documentation for all the kit parts. If you come across any useful documentation that you think everyone should be aware of then leave a comment or drop me a message and I will add it here.
Product
Manufacturer Part Number
Farnell Order Code
Documentation / Guides
220957-0104
4328214
Datasheet
Drawing
220957-0108
4328215
Datasheet
Drawing
220957-0001
4328208
Datasheet
Drawing
220957-0008
4328211
Datasheet
Drawing
220957-0116
4328216
Datasheet
Drawing
220957-0011
4328212
Datasheet
Drawing
EVAL-ADIN1110EBZ
4032785
User Guide
EVAL-ADIN1100EBZ
4032784
User Guide
RPI4-MODBP-4GB
3051887
Datasheet
Enhanced Product Overview
EVAL-CN0575-RPIZ
4203675
Datasheet
410-221
2290114
Datasheet
  • veluv01
    veluv01 9 months ago +4
    Thanks for setting this up! Really appreciate having all the documentation in one place. I'm currently setting up the Kuiper Linux (on the RPi 4) for CN0575. Here's some of the resources for flashing…
  • JWx
    JWx 9 months ago +2
    posted another update - I am currently in the process of choosing replacement waterproof enclosure - the one from Extreme Environment design challenge has slightly too large opening, which could lead to…
  • vmate
    vmate 9 months ago +1
    Well, it seems like luck is not on my side for this project, after weeks of trying, FedEx refused to deliver the package to me, so I still don't have it. It looks like I will be designing a custom PCB…
  • veluv01
    Here's some of the resources for flashing Kuiper Linux onto the Raspberry Pi SD card and getting started with the CN0575
    https://www.analog.com/en/resources/evaluation-hardware-and-software/embedded-development-software/kuiper-linux.html#software-overview , https://wiki.analog.com/resources/tools-software/linux-software/kuiper-linux , https://analogdevicesinc.github.io/documentation/solutions/reference-designs/eval-cn0575-rpiz/index.html
  • JWx
    JWx 9 months ago
    posted another update - I am currently in the process of choosing replacement waterproof enclosure - the one from Extreme Environment design challenge has slightly too large opening, which could lead to unreliable gasket contact. I have first thought about using additional seal but it may be against proper testing methodology so I will probably use another one...
  • JoRatcliffe
    JoRatcliffe 9 months ago in reply to JWx
    I'm sorry it sounds like it might not be working out but it's a neat idea trying to use the waterproof enclosure from the previous extreme environment challenge :)
  • JWx
    JWx 9 months ago in reply to JoRatcliffe
    No problem - I have a few of them (my Extreme Environment projects were about comparing parameters inside different enclosures), but E14 branded one would be nice to use. Unfortunately, opening cut for really similar connector turned out to be about 2mm larger than needed. Mount can be installed but there is some leeway that could cause unneeded complications later, so I would probably either drill a second opening or use different enclosure - still trying to decide what would be better for the project Slight smile
  • vmate
    vmate 9 months ago
    Well, it seems like luck is not on my side for this project, after weeks of trying, FedEx refused to deliver the package to me, so I still don't have it. It looks like I will be designing a custom PCB around the ADIN chip, but that could be problematic too due to Chinese New Year, and JLCPCB shutting down for a week or so.
    Thankfully the SPE unrelated parts of my project are coming along nicely though, let's hope I get everything in time to actually finish it. Worst case scenario, I use CANbus, and color my cables green with a sharpie to pretend it's SPE over the Molex cables :P
  • JWx
    JWx 9 months ago in reply to vmate
    sorry to hear that - hope you will get your kit in time to actually make use of it...
  • JWx
    JWx 8 months ago
    I have one comment to the list above - as veluv01  has first discovered, we have two different socket mounts in the kit: 220957-0011 and 220957-0012 - one installable from the outside and another installable from the inside of enclosure...
