Experimenting with Thermal Switches
  • Experimenting with Thermal Switches
Challenge Blog #Blog 5 Testing the system using water
  • Challenge Blog
  • RoadTests
  • Author Author: manojroy123
  • Date Created: 23 Mar 2022 1:47 PM Date Created
  • Views 4904 views
  • kemet
  • experimenting with Thermal Switches
manojroy123
manojroy123
23 Mar 2022
We have build a lot of parts for the project. Like the liquid heating element, temperature switch etc. Before assembling the whole system. We feel that each parts of the system should be tested. Video 1 shows the working system of the parts in water.
Video 1
Liquid heating element and it’s working:-
The liquid heating element is made of a 3.3 ohm 50 watt resistor and a heat pipe. When 3.3 ohm resistor is connected to 12 volt power supply the resistor gets hot, these heat is transferred to water using heat pipe. Thermal conductivity of heat pipe is very high. Which helps in rising the temperature of water. Figure 1 shows the working structure
Figure 1
Thermal switch:-
We have used thermal reed switch provided by kemet with switching temperature at 50’c. the connecting ends of the switch is insulated using hot glue. So that the switch doesn’t gets shorted in water. Figure 2 shows the assembled switch.
Figure 2
Product no OHD1-50B. 50'C THERMAL GAURD SWITCH
    DAB over 4 years ago
    Have you verified that the hot glue does not change the thermal characteristics of the switch?
