Experimenting with Waterproof Connectors
  • Experimenting with Waterproof Connectors
Blog E.W.C Blog 5 - Stress it!
Join Experimenting with Waterproof Connectors to participate - click to join for free!
  • Author Author: me_Cris
  • Date Created: 28 May 2023 1:56 PM Date Created
  • Views 1582 views
  • Comments 13 comments
  • experimenting with Waterproof Connectors
me_Cris
me_Cris
28 May 2023
Hello everyone!
Another blog about waterproof connectors, and another tough test I might say. Until now, I have tried to see what results I get with these connectors in heavy conditions, high humidity, let's say, but I rather accelerated this process and after assembling all the parts I immersed the case in water.
I know from the forum that there were other people who had some problems in this regard, the infiltration of water.
I had to do a little work on the RJ45 plug because the screw in the plug broke during the first assembly attempt, probably because the pitch of the thread did not match. Finally, with the help of a friend who has the right tools, I rethreaded the socket and used longer screws.
At the first attempt, I did not manage to properly seal the area around the RJ45 plug, and a lot of water seeped in, but now I tried again and I can say that things have improved. It's like I still see a bubble here and there, but the water has not infiltrated like in the first attempt.
In the next step, I also added wires, so that I can see how well those plastic nuts from the plugs seal, how well they tighten on the wires, because it is a rubber seal that closes on the cable sheath.
I put wires on the plugs that I can use for this challenge, that is, plugs that will be connected to the LattePanda board. I put a wire on the USB plug, and another wire on the MRD plug with 4 positions.
To make things a little more interesting, I put an LED on each wire, so when I put the case in water, if I don't notice water seeping into the plugs, I'll test if the LEDs light up. It is quite clear that water and electronic components do not get along. Laughing
image image
I also have two videos: https://drive.google.com/file/d/1TckZrc8hhkMgboSv8Sc4vRG_OYHctfIc/view?usp=sharing and https://drive.google.com/file/d/1VGnF1U6phFCEljB06dSKxIWDmIMFfXT0/view?usp=sharing
As you can see in the video, no short circuit occurred, the LEDs did not burn out, even if the entire case is in water.
Anyway, under the conditions in which I proposed to use this enclosure, the problem of immersion in water will never arise, the work environment is not a swimming pool. Even so, it is not 100% safe.
That's about it for now. Another blog is coming.
Thank you. Have a nice day!
  • rscasny
    rscasny over 3 years ago
    Could you upload the videos so they appear on the page and people don't need to go to google drive? If you can, I'd appreciate it.
    Randall
  • rscasny
    Randall
  • me_Cris
    me_Cris over 3 years ago in reply to rscasny
    Hi! The videos have a large size and from some reason do not upload, but I will try again when I have time..
  • rscasny
    rscasny over 3 years ago in reply to me_Cris
    I understand that happens. When you have an opportunity, try once more. Thanks.
  • me_Cris
    Did you see my reply regarding the final blog due date?
  • ralphjy
    ralphjy over 3 years ago in reply to me_Cris
    Have you tried uploading to YouTube and inserting that link?  I’ve had to do that for videos > 200MB.  That will allow the video to play on the page.
  • rscasny
    Yes, I responded. But if there were shipping problems, which are usually beyond your control, I usually give some more time. Message me about it.
    Randall
