Experimenting with Waterproof Connectors
  • Experimenting with Waterproof Connectors
Blog E.W.C Blog 5 - Stress it!
Join Experimenting with Waterproof Connectors to participate - click to join for free!
  • Author Author: me_Cris
  • Date Created: 28 May 2023 1:56 PM Date Created
  • Views 1558 views
  • Comments 13 comments
  • experimenting with Waterproof Connectors
me_Cris
me_Cris
28 May 2023
Hello everyone!
Another blog about waterproof connectors, and another tough test I might say. Until now, I have tried to see what results I get with these connectors in heavy conditions, high humidity, let's say, but I rather accelerated this process and after assembling all the parts I immersed the case in water.
I know from the forum that there were other people who had some problems in this regard, the infiltration of water.
I had to do a little work on the RJ45 plug because the screw in the plug broke during the first assembly attempt, probably because the pitch of the thread did not match. Finally, with the help of a friend who has the right tools, I rethreaded the socket and used longer screws.
At the first attempt, I did not manage to properly seal the area around the RJ45 plug, and a lot of water seeped in, but now I tried again and I can say that things have improved. It's like I still see a bubble here and there, but the water has not infiltrated like in the first attempt.
In the next step, I also added wires, so that I can see how well those plastic nuts from the plugs seal, how well they tighten on the wires, because it is a rubber seal that closes on the cable sheath.
I put wires on the plugs that I can use for this challenge, that is, plugs that will be connected to the LattePanda board. I put a wire on the USB plug, and another wire on the MRD plug with 4 positions.
To make things a little more interesting, I put an LED on each wire, so when I put the case in water, if I don't notice water seeping into the plugs, I'll test if the LEDs light up. It is quite clear that water and electronic components do not get along. Laughing
image image
I also have two videos: https://drive.google.com/file/d/1TckZrc8hhkMgboSv8Sc4vRG_OYHctfIc/view?usp=sharing and https://drive.google.com/file/d/1VGnF1U6phFCEljB06dSKxIWDmIMFfXT0/view?usp=sharing
As you can see in the video, no short circuit occurred, the LEDs did not burn out, even if the entire case is in water.
Anyway, under the conditions in which I proposed to use this enclosure, the problem of immersion in water will never arise, the work environment is not a swimming pool. Even so, it is not 100% safe.
That's about it for now. Another blog is coming.
Thank you. Have a nice day!
  • JWx
    JWx over 3 years ago
    Good to know you have managed to seal this RJ45. Out of curiosity - can this thread be recreated using standard tools? I have modified threads in computer rails (original were imperial but I have to modify them to metric because of screw availability) but this RJ45 doesn't look like typical metal (steel or alu) to me...
  • me_Cris
    me_Cris over 3 years ago in reply to JWx
    At the first attempt, it was quite bad, next to the RJ45 plug, a lot of water seeped in. Now it's ok.
    I used a metric screw.
    It's not a very hard metal (I'm referring to RJ45), it's an alloy, but using a tap (look for a metal tap) grower you'll end up doing a good job.
  • ralphjy
    ralphjy over 3 years ago in reply to me_Cris
    Interesting, it looks like you drilled through the housing where the screws insert.  The housing is supposed to be sealed to prevent leakage.  That’s why you have to make sure the screw is short enough that it does bottom out and prevent the gasket from seating.
    Anyway, glad you made it work.
  • JWx
    JWx over 3 years ago in reply to ralphjy
    I think that RJ45 enclosure was drilled to allow thread rework - didn't noticed openings in the previous blog...
  • JWx
    JWx over 3 years ago in reply to me_Cris
    ok - I have found it - it is made of nickel-plated zinc... Not surprising it looked unfamiliar...
  • me_Cris
    me_Cris over 3 years ago in reply to ralphjy
    I had some problems, a screw broke and I needed some mechanical work, let's say. I had nothing to do but drill the hole all the way and then redo the thread.
  • ralphjy
    Understood.  It was an observation, not a criticism.
    I realized that my comment had a typo, but can't correct it with the editor - should have been "make sure the screw is short enough that it does not bottom out and prevent the gasket from seating".  I wish the gasket were slightly thicker.
  • ralphjy
