Experimenting with Waterproof Connectors
  • Experimenting with Waterproof Connectors
Experimenting with Waterproof Connectors Forum Turning Lattepanda on without using power button
Join Experimenting with Waterproof Connectors to participate - click to join for free!
  • Replies 15 replies
  • Subscribers 35 subscribers
  • Views 4974 views
  • lattepanda
  • experimenting with Waterproof Connectors
charlieo21
charlieo21 over 3 years ago
I was having some problems with the Lattepanda software, I had to reinstall Windows, when I was doing it I found in the bios that you can enable a function that turn the lattepanda on when power is provided.
  • ralphjy
    ralphjy over 3 years ago +1
    I ended up doing that too. Once the enclosure is buttoned up, it's pretty painful to get to the power button . I've seen that some people add a remote power button, but I don't really have a need for…
  • charlieo21
    charlieo21 over 3 years ago in reply to JWx +1
    Basically I was trying to clean some space in the limited eMMC and ended with a system that doesn't work anymore. I tried to reinstall using the image from their site but doesn't work because everything…
  • charlieo21
    It must be stored in some place that it's read only
  • charlieo21
    charlieo21 over 3 years ago in reply to dougw
    In my case the recovery process wasn't working either
  • ralphjy
    ralphjy over 3 years ago in reply to charlieo21
    Good to know in case I need to re-install.  I imagine that we are all running headless (those of us that have the lattePanda inside the enclosure), but I am careful to always shutdown Windows before turning off power.  I do that as a matter of course with any OS, but I imagine there will always be potential issues with power failure...
  • JWx
    JWx over 3 years ago in reply to charlieo21
    maybe you were bitten by the same problem as I have experienced - manual says: insert usb disk, cycle power and it will reinstall.
    It assumes BIOS boot order of: "USB drive then internal disk", but in my case it was "internal disk then USB drive". Had to change boot order and reinstall gone as stated in the manual...
  • charlieo21
    That's right, I had to change the boot order
