Design Challenges
Design Challenges
Forum Electricaly controled mechanical device needed
  • Blogs
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 10 subscribers
  • Views 3462 views
  • Design
inception007
inception007 over 10 years ago
Any available device that can control water flow in pipe ( by allowing or blocking pipe ) when triggered  with electrical signal.?@
  • D_Hersey
    0 D_Hersey over 10 years ago
    Alternative supplier:
    Gravity Feed Capable, 1 2 items in valves4projects store on eBay!
  • inception007
    0 inception007 over 10 years ago
    Thanks John, its more helpful.
    Stay safe be blessed
    0 jw0752 over 10 years ago
    Hi Aemal,
    I don't know your location but here is the US a company named Grainger has a system of solenoid valves and coils where you can pick the type and volume of the valve and match it to a coil with the voltage and current type that you need for your application. Here is a link.
    http://www.grainger.com/category/plumbing-plumbing-valves-solenoid-valves-and-coils/ecatalog/N-ri2/Ntt-solenoid+valves?nls=3&ssf=3&sst=subset&ts_optout=true
    I am sure that there are many other sources. In your location seek out a company that repairs dental equipment and they may have a source as well as used solenoids in case you just want to experiment.
    0 michaelkellett over 10 years ago
    There are loads (thousands) of such devices, usually described as motorized (motorised if English) valves or solenoid valves.
    Try Googling to find some local suppliers.
    (Of course Farnell/E14 have some !)
