Design Challenges
Design Challenges
Forum Electricaly controled mechanical device needed
  • Blogs
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 10 subscribers
  • Views 3580 views
  • Design
inception007
inception007 over 10 years ago
Any available device that can control water flow in pipe ( by allowing or blocking pipe ) when triggered  with electrical signal.?@
  • inception007
    0 inception007 over 10 years ago in reply to Jan Cumps
    No problem,but it was not for me. i keep my work public. Also have a look of my other question u might help me
    0 Jan Cumps over 10 years ago in reply to inception007
    I was actually trying to tell that I was not going to write the blog for you image
  • inception007
    Thanks...Would love to see it from you. I am starting a new conversation on new problem..Hope i will get help here
    I'm kindly going to pass on that task image.
  • inception007
    ok.. I dont have any experience about blogging.. However i will share my whole work in document editor with you and you are free to write it in blog  that might help others
  • clem57
    0 clem57 over 10 years ago
    100% Brand new and high quality
    Model:2W-025-08
    Working Medium: Air, Water, Oil
    Operating Method: Direct action
    Type: Normal Closed
    Flow bore: 2mm
    Pipe Size: 1/4"
    Working Pressure:  0.15~0.8Mpa
    Max Pressure:1.0Mpa
    Working Temperature: -5~60℃
    Voltage: DC 12V
    Material: Brass
    What other operating methods are there?
    Clem
    Cool. Have fun. Write a blog about it here on element14 please image
  • inception007
    I bought 12V solenoid valve from local store just for experimental purpose and it worked ,its china made and not expensive. I need it to control inflammable gas through mq4 sensor.
    Have a look of below link.
    Quality 12V DC 1 4" Electric Solenoid Valve Water Air Fuels Gas Normal Closed | eBay
    What device did you select in the end?
  • inception007
    0 inception007 over 10 years ago in reply to D_Hersey
    I am really thankful to all of you. I found the device by mentioning its name in electronic store..
    THANKS to element14 community for helping me out.
