Design Challenges
Design Challenges
Forum UPCOMING - Have You Experimented with Flyback Transformers? If Not, Step Up and Participate to Win Big Prizes - Seeking Your Feedback
  • Blogs
  • Replies 7 replies
  • Subscribers 12 subscribers
  • Views 3481 views
  • EXPERIMENTING WITH FLYBACK TRANSFORMERS
rscasny
rscasny over 3 years ago
Greetings to All!
I am preparing to launch a new Experimenting Challenge activity focusing on  flyback transformer experiments.
I wanted to tell you about it before I launch it.
I'd like to give you some facts and let you see what I am thinking about during my planning stage with the sponsor.
I'd also like to hear your thoughts about what you might like included in the kit.
The kit will contain twelve different flyback transformers (Scroll down to see). I would consider adding things to the kit. I'd like to hear your suggestions. You can post in the comment sections below.
Of course, there will be some great prizes as well. Here are the prizes I am considering:
Grand Prize
Handheld Oscilloscope
NEW! Beagle V-Ahead
DC Electronic Load
For More Info For More Info For More Info
Runner Up Prize
Hot Air Station
DC Power Supply
NEW! Beagle V Ahead
Finisher Prize
Heat Shrink Kit
For More Info
Before I get into the details, I thought it might be good to pose the question:
Here's something to chew on:
A flyback transformer is a coupled inductor with a gapped core. During each cycle, when the input voltage is applied to the primary winding, energy is stored in the gap of the core. It is then transferred to the secondary winding to provide energy to the load. Flyback transformers are used to provide voltage transformation and circuit isolation in flyback converters.
Here's the parts the sponsor selected for the kit:
(A couple of images)
image image
Here are the product pages. (Note: some of these are new products so all the info may still need to be loaded on the page.)
Product Description See Entire Kit
PFBR45-ST13150S Gate Drive Transformer, 1MH, 2KV  See Here
PFBR45-ST13150S Gate Drive Transformer, 1.15MH, 4.5KV See Here
BA60951CS XFMR, SMPS, FLYBACK, 2.5KV See Here
SM13117EL Ethernet & LAN Transformer, PoE, 1 Port, 1:0.5:0.5:0.5, 350 µH, 1.5 kV, Surface Mount See Here
063929 SMPS Transformer, Flyback, 250 mA, 44kHz to 132kHz, 4 W, 85V to 265V See Here
063932 SMPS Transformer, Flyback, 250 mA, 44kHz to 132kHz, 6 W, 85V to 265V See Here
093830 SMPS Transformer, Flyback, 650 mA, 132kHz, 8 W, 85V to 265V See Here
063934 SMPS Transformer, Flyback, 370 mA, 44kHz to 132kHz, 9 W, 85V to 265V See Here
094931 SMPS Transformer, Flyback, 1.8 A, 66kHz to 132kHz, 22 W, 85V to 265V See Here
094932 SMPS Transformer, Flyback, 1.2 A, 132kHz, 22 W, 85V to 265V See Here
071923 Choke, Common Mode, 0.28 A, 22 mH, Through Hole See Here
093267 Choke, Common Mode, 0.5 A, 27 mH, Through Hole See Here
D00413 Compartment Box, Clear, Plastic, General Purpose Storage, 35x125x230mm See Here
Datasheets on some of the parts:
a. https://www.farnell.com/datasheets/3742805.pdf
b. https://www.farnell.com/datasheets/3774338.pdf
c. https://www.farnell.com/datasheets/2868806.pdf
d. https://www.farnell.com/datasheets/3967078.pdf
e. https://www.farnell.com/datasheets/3967079.pdf
f. https://www.farnell.com/datasheets/3967080.pdf
g. https://www.farnell.com/datasheets/3967081.pdf
  • rscasny
    rscasny over 3 years ago in reply to misaz
    Thanks  for mentioning this. I took a look at this. Different regions would have different connectors.
    I came up with these:
    Optional Power Supply:
    Based on the location of the experimenter, we will optionally provide a power adapter to the kit, as needed:
    AC/AC Power Supply UK Plug - AC/AC Power Supply EU Plug
    AC/AC Power Supply US Plug
    Since we work with members from all over, I would consider offering this if you need one. I'll add a question on the application entry form regarding the need for a power adapter.
    Randall
    --element14 community team
  • rsc
    rsc over 3 years ago
    Probably too small for tesla coil action..........
    Scott
  • misaz
    misaz over 3 years ago
    Looks good. While some transformes are suitable for using with mains I would welcome AC/AC adapter which safely makes lower AC voltage for making many experiments much safer. For example this one: https://uk.farnell.com/ideal-power/77db-12-24m/power-supply-ac-ac-18w-24v-0-5a/dp/2368017
    DAB over 3 years ago
    These types of transformers were a big deal back in the day of analog TV's.
    We tested them in Tech School as they were a major component.
    shabaz over 3 years ago
    I suspect contestants will create some extremely interesting, fun or useful projects for this Experimenting Challenge : )
    dougw over 3 years ago
    Bourns has a nice app note on how to design a power supply with these transformers:
    https://www.bourns.com/docs/technical-documents/technical-library/inductive-components/application-notes/Bourns_Consumer_Grade_Flyback_Power_Supply_Appnote.pdf?sfvrsn=0
  • kmikemoo
    kmikemoo over 3 years ago
    I didn't know what a flyback transformer was until I read the  explanation above. I'll be interested to see how these get applied.
