Design Challenges
Design Challenges
Forum Seeking Feedback on Kit for Upcoming Experimenting with Extreme Environments
  • Blogs
  • Replies 24 replies
  • Subscribers 17 subscribers
  • Views 4519 views
  • experimenting challenge survey
rscasny
rscasny over 2 years ago
At least once a year, I try to do some activity along the lines of protecting electronics. In 2023, I launched Experimenting with Waterproof Connectors. In late 2021, we launched the Just Encase Design Challenge. As more electronics are employed outdoors and more IOT solutions are installed in remote locations in the open environment, the need to protect electronics is increasing.
In the challenge I am now planning, I hope to take the idea of "electronics environmental protection" to the extremes.
In brief, the challengers will be given a kit to build something -- anything. They will house their electronic-builds in a durable, IP65-67 enclosure. After doing those the things, the real fun begins.
We would like the participants to experiment with extreme environments such as hot & cold temperatures, light & strong water sprays, vibrations, dust "storms," etc. You get the idea. They will need to design a testing environment to simulate the extreme condition being tested and then put their protected-build in it. And write about it.
Feedback on Proposed Kit
For the remainder of this discussion, I will overview selections for the kit. I have three options each for:
  • Electronics
  • Enclosure
  • Display
  • Sensor Connector
Please vote for your preference of each kit component. Now, if you have an alternate suggestion, feel free to post a comment.
I would like the electronic-builds to be battery-powered since a lot of remote monitoring is battery powered. Take a look at the viability of that. If that doesn't work, I may then give special extra credit to those participants that have a battery-powered experiment. At this point, I am in the planning stage. Not everything is cast in stone, so to speak.
Of course, there other parts such as cables, other types of connectors, power supplies, sensors, etc. that I have not included in this preliminary kit. Go ahead and post a comment on the accessories you would like.
Thanks for participating in this discussion.
Here are the polls:
ELECTRONICS under consideration
MICROCHIP EV36W50A WFI32-IOT Board, 32bit, PIC
Datasheet
Raspberry Pi Compute Module 4 Lite and I/O Board
Datasheet
ARDUINO AKX00034 EDGE CONTROL BOARD
Datasheet
Display under consideration
ADAFRUIT 2260 TFT Display
Datasheet
MIDAS MC42005A6W-SPTLYI-V2 DISPLAY, ALPHANUMERIC, 20X4
Datasheet
MIKROE-55 Display, Character LCD 2x16
Datasheet
ENCLOSURES under consideration
HAMMOND 1554VA2GYCL, Plastic Enclosure, IP68
Datasheet
HAMMOND 1590Z231GY Metal Enclosure, Small, Diecast Aluminum, IP68
Datasheet
HAMMOND 1555HF17GY Plastic Enclosure, Watertight, Industrial, IP67
Datasheet
SENSOR CONNECTOR under consideration
AMPHENOL MRDBG02L13000, Circular Connector, 2 Contacts
Datasheet
AMPHENOL MRDBG03L13000, Circular Connector, 3 Contacts
Datasheet
AMPHENOL MRD-BG04-L13-000, Circular Connector, 4 Contacts
Datasheet
    DAB over 2 years ago in reply to rscasny
    Looks like a good starting set, depending upon the applications.
  • rscasny
    Hi All.
    Thanks for the feedback.
    At this point, here is what I am considering for the final version of the kit. Some of the choices are based on inventory and availability.  Take a look. I open flexible here with substitutions, etc. Thanks. (working on the prizes next)
    Single Board Computer
    Pi4 Compute Modulelearn more
    Pi 4 Compute module IO Board Learn More
    Display
    Midas 20/4 displaylearn more
    Connectors
    Male-cable mountlearn more
    Female-cable mountlearn more
    Receptacle panel mountlearn more
    Enclosure
    IP68, Clear Toplearn more
    Antenna
    IOT Antenna, WiFi, BLElearn more
  • rsc
    rsc over 2 years ago
    That's kinda funny, because I designed a small 3d printed enclosure a few months ago for a sensor to be placed in rocks to chart their movement.
  • JWx
    JWx over 2 years ago in reply to kmikemoo
    this website suggests possible range beyond -20°C to +70°C (for some versions/variants at least):
    https://www.papercast.com/product/your-big-questions-how-do-papercast-e-paper-displays-perform-in-hot-cold-climates/
  • kmikemoo
    kmikemoo over 2 years ago in reply to JWx
     JWx I LIKE IT!  Great suggestion.  Does e-Ink work in extreme cold/hot?  Man!  Now I gotta charge up my Adafruit MagTag and see.  It's not exactly "extreme" right now, but the MagTag is not doing anything useful at the moment anyway.
  • JWx
    and about display - maybe some e-Ink display would be interesting? There are versions with extended temperature range and power consumption would be great for battery operated systems...
  • kmikemoo
    Very cool.  How did I miss this one?  Joy  Liking the Pi because my idea for an application already runs on the Pi and I can concentrate on the enclosure stuff.  Should be VERY interesting.
  • obones
    obones over 2 years ago in reply to rscasny
    Ah so that leaves the "super hot weather" part of my test idea which was a floating device inside the water tank to report water level and temperature
  • embeddedguy
    embeddedguy over 2 years ago
    All the mentioned device are great for smart enclosure, I voted for RPI compute module but I also like other two modules. Specifically RPI compute modules can be good for industrial setting, where power and ethernet can be used with PoE hat.. Networking related projects can be done fast in this case. Otherwise for normal wireless IoT projects other two modules are great. Great to see Arduino board that has many connectivity options....!!....I am yet to experiment with tight waterproof enclosures. Never got my hands on it...yet
  • rscasny
    rscasny over 2 years ago in reply to JWx
    This particular project is launching in the last week of January.
