Design Challenges
Design Challenges
Forum Seeking Feedback on Kit for Upcoming Experimenting with Extreme Environments
  • Replies 24 replies
  • Subscribers 17 subscribers
  • Views 4141 views
  • experimenting challenge survey
rscasny
rscasny over 2 years ago
At least once a year, I try to do some activity along the lines of protecting electronics. In 2023, I launched Experimenting with Waterproof Connectors. In late 2021, we launched the Just Encase Design Challenge. As more electronics are employed outdoors and more IOT solutions are installed in remote locations in the open environment, the need to protect electronics is increasing.
In the challenge I am now planning, I hope to take the idea of "electronics environmental protection" to the extremes.
In brief, the challengers will be given a kit to build something -- anything. They will house their electronic-builds in a durable, IP65-67 enclosure. After doing those the things, the real fun begins.
We would like the participants to experiment with extreme environments such as hot & cold temperatures, light & strong water sprays, vibrations, dust "storms," etc. You get the idea. They will need to design a testing environment to simulate the extreme condition being tested and then put their protected-build in it. And write about it.
Feedback on Proposed Kit
For the remainder of this discussion, I will overview selections for the kit. I have three options each for:
  • Electronics
  • Enclosure
  • Display
  • Sensor Connector
Please vote for your preference of each kit component. Now, if you have an alternate suggestion, feel free to post a comment.
I would like the electronic-builds to be battery-powered since a lot of remote monitoring is battery powered. Take a look at the viability of that. If that doesn't work, I may then give special extra credit to those participants that have a battery-powered experiment. At this point, I am in the planning stage. Not everything is cast in stone, so to speak.
Of course, there other parts such as cables, other types of connectors, power supplies, sensors, etc. that I have not included in this preliminary kit. Go ahead and post a comment on the accessories you would like.
Thanks for participating in this discussion.
Here are the polls:
ELECTRONICS under consideration
MICROCHIP EV36W50A WFI32-IOT Board, 32bit, PIC
Datasheet
Raspberry Pi Compute Module 4 Lite and I/O Board
Datasheet
ARDUINO AKX00034 EDGE CONTROL BOARD
Datasheet
Display under consideration
ADAFRUIT 2260 TFT Display
Datasheet
MIDAS MC42005A6W-SPTLYI-V2 DISPLAY, ALPHANUMERIC, 20X4
Datasheet
MIKROE-55 Display, Character LCD 2x16
Datasheet
ENCLOSURES under consideration
HAMMOND 1554VA2GYCL, Plastic Enclosure, IP68
Datasheet
HAMMOND 1590Z231GY Metal Enclosure, Small, Diecast Aluminum, IP68
Datasheet
HAMMOND 1555HF17GY Plastic Enclosure, Watertight, Industrial, IP67
Datasheet
SENSOR CONNECTOR under consideration
AMPHENOL MRDBG02L13000, Circular Connector, 2 Contacts
Datasheet
AMPHENOL MRDBG03L13000, Circular Connector, 3 Contacts
Datasheet
AMPHENOL MRD-BG04-L13-000, Circular Connector, 4 Contacts
Datasheet
    dougw over 2 years ago in reply to robogary
    I assume MKR compatible means it should work fine with a MKR1000, you just won't have the wireless connectivity of the RF MKRs..
    LEDs are usually good in the cold - do they have batteries? Which do not generally like the cold....
  • robogary
    robogary over 2 years ago
    I got a smirk to myself  when I saw the Arduino Edge could run 34 months on a 5Ahr battery :-)  Good for apps on Mars, but not on Jupiter.
    Actually the Arduino got my attention because of the low sleep consumption and farming gpps. The board is compatible with MKR Boards 2G/3G/CatM1/NBIoT, LoRa, Sigfox and WiFi/BT connectivity.
    I had mentioned my electronics inventory is getting like the Smithsonian as the boards design lifetimes are short. Im not sure my MKR1000 is relevant for use anymore. Could an appropriate control board be provided with the road test ?
    Displays are also a good second choice for outdoor apps.
    I wish to now formally complain again about my LED lightbulbs that quit working in freezing temperatures. Luckily, they come back on when the temps are above freezing.
    My 2 cents...
    Great MCU modules, but for me the edge goes to Arduino because it is easier to interface.
    The displays are good to -20 but for me the edge goes to the Midas - I think it will be more readable outdoors.
    The box needs to be 1554 because you need to see the display through the clear lid.
    The connector needs to be 4 pins - these controllers can do more than a 2 wire interface.
