Design Challenges
Design Challenges
Forum Raspberry Pi - Monitoring Seawater Values
  • Blogs
  • Subscribers 6 subscribers
  • Views 1794 views
  • frontpage
Hi, I was wondering if it was possible to design a raspberry pi to monitor the value within a marine fish tank. It wouldn't have to measure specific values as such but possibly more a variation of what would be the calibration solution (natural seawater). Basically from the variation i you could decide a water change is needed. Would this still need to measure each specific value ? If the later is it possible to probe or sensor the following ?
Calcium - in ppm
Alkalinity - in dKH
Salinity - in ppt or sg
PH -
Magnesium - in ppm
Phosphate - in ppm
I appreciate there will be alot of coding required but there is also alot around to help.
Sorry i hope this makes sense i have very limited knowledge in this field but i am still reading and learing about the possibilities ! Any help is appreciated.
    DAB over 9 years ago
    Hi Steve,
    The sensors to measure the water properties you want are expensive.
    I think you will find that it is simpler and less expensive to just follow the normal tank owners guideline based upon the contents of your sea water tank.
    I remember when I owned a hot tub.  I tried to do the weekly measurements and adjust the ph and other factors on a weekly basis.
    The results were not to my liking.  I actually found that if I just balanced the initial refill, the water actually stayed very stable for months without adjustments with normal use.
    I think you will find that most sea water tank owners experience a similar condition.  As long as you are not disturbing the tank, it should remain stable for a good period of time.
  • dimstamat
    dimstamat over 9 years ago
    Hi Steve,
    A water change is recommended on regular basis, even when parameters seem to be good! However, it would be nice to have sensors for all these parameters and avoid performing the liquid tests. I know it is pretty easy to connect a pH sensor to raspberry pi and maybe a salinity sensor. However, calcium, magnesium, etc might be harder to measure and the tools I find are really pricey. Let me know if you find something for measuring the salinity. So far, I found this one:
    http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=&products_id=2233
    Dimos
