Design Challenges
Design Challenges
Forum SD Card Program
  • Blogs
  • Replies 7 replies
  • Subscribers 7 subscribers
  • Views 1475 views
SD Card Program
I'm combining some programs in PSOC creator 3.3 .I'm working on PSoC4 Ble. I have a program of SD Card, But i couldn't found that it is working or not. I'm attaching my project please revert me that how to find that the program is correct or not, If it is not giving any error.
Thank You
SDCard_Demo-000.Bundle01.zip
    balearicdynamics over 11 years ago in reply to e14 Contributor
    Yup! let me know if things goes right.
    Enrico
    e14 Contributor over 11 years ago in reply to balearicdynamics
    Thank You  Enrico.
    To be honest, my though is that it is ... a typo image or (due mi ignorance) another way to call a signal usually called in a different way.
    So, I suggest the following:
    1. Connect as in your design and as far as you know the other pins
    2. See if the only remaining pin is this and connect to the remaining signal. If it work we know what it is else if not, if you don't put direct VCC I think that you can't damage it.
    3. Check with a tester (that is the reason that I sent you the truly SD card specifications, to avoid errors as this is a sort of official documentation) where this strange name pin in the breakout is connected to your sd card slot (that should correspond pin-to-pin) to the effective sd card pins). You should see what do they means with this signal.
    The advantage (and disadvantage in some cases) of the breakout boards is that are a bare "pin export" from a chip that for some reason, i.e. SMD soldering etc., are difficult to use in a breadboarding environment.
    Enrico
    Thank you Enrico. I saw this document & some datasheets also but couldn't find SLD pin & specification about it. My program is working but first i need to coonect SLD pin with controller. You know what is SLD pin in SD Card breakout & connection with controller.
    Hello, please find the SD card specification document, you find a clear explanation of all the essential signals to communicate with the reader.
    https://www.sdcard.org/downloads/pls/simplified_specs/archive/partE1_100.pdf
    Enrico
    I want to know about SLD pin in SD Card Breakout & connection of SLD pin with PSoC board. This is my first project, I don't have much idea about it.image
  • ravi_butani
    ravi_butani over 11 years ago
    Its so simple... Connect SD card with PSoC and see is it working or not...
