Blog Cam-e-lot - Round 2 - Man vs EnOcean Pi board
  • Author Author: amgalbu
  • Date Created: 7 Aug 2014 4:13 PM Date Created
  • Views 673 views
  • forget_me_not
  • iot_cam-e-lot
amgalbu
amgalbu
7 Aug 2014
Next step in the ForgetMeNot project is to make the EnOcean PI board work.
As I said, my purpose is to write a C++ application, so I need the be able to cross-compile the source code to control the EnOcean Pi board and embed it into my application. Fortunately, EnOcean provides a valid library to use as a starting point
So, these are the steps for this round
  1. I downloaded the EnOcean link library from http://www.element14.com/community/servlet/JiveServlet/download/55295-6-118009/EnOcean+Link+%28Trial%29+V1.2.0.0.zip
  2. I extracted all the files in a directory of the host system (/home/gpavoni/rpi/EnOcean)
  3. I launched Eclipse and imported the three projects in the directory /home/gpavoni/rpi/EnOcean (namely EOLink, examples and tutorials)
  4. All the three projects does not compile out-of-the-zip. Some changes in the configurations were required. For each project, I had to open the Project Properties window and change the following settings (make the changes to all the build configuration you want to use - I'm going to use ReleaseLib)
    • C/C++ Build -> Toolchain Editor
      • Set "Cross GCC" in the "Current toolchain"
    • C/C++ Build -> Settings -> Tools Settings
      • Set Prefix to arm-linux-gnueabihf-
      • Set Path to the full path of the toolchain (/home/gpavoni/rpi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/)
    • Only for EOLink project, C/C++ Build -> Settings -> Build Artifact
      • Set Artifact type to "Shared library"
      • Set Artifact extension to "a"
      • Set Output prefix to "lib"
  1. Build the EOLink library
  2. Copy libEOLink.a in /usr/lib
  3. In the "examples" project, open the Gateway_example.cpp file and change the #define SER_PORT to "/dev/ttyAMA0"
  1. In the "examples" project, open the sandbox.cpp file and uncomment the "gatewayExample()" line and comment the "ptmExample();" line
  1. Build the "examples" project
  2. Now you can copy the libEOLink.a file (located in /home/gpavoni/rpi/EnOcean/EOLink/ReleaseLib or /usr/lib) to usr/lib on the Raspberry board and grant execution permissions (sudo chmod +x libEOLink.a)
  3. Copy the examples executable (located in /home/gpavoni/rpi/EnOcean/examples/Release) in your home directory on the Raspberry board and grant execution permissions (sudo chmod +x examples)
  4. Next step is to free the serial port on the Raspberry board. Follow this exceptionally clear tutorial: Free Your Raspberry Pi Serial Port | Raspberry Pi Spy
  5. Now launch ./examples from you home directory
  6. Press buttons on the EnOcean sensors and you should see telegrams coming through
    mcb1 over 12 years ago
    Nice work.
    Releasing yourself from some of the overhead of existing applications allows so much more of this technology.
    Hopefully you'll be contributing it as OSS.
    Nice work.
