Blog Did I remember to close the diaper wipe box?
  • Author Author: electronichamsters
  • Date Created: 29 Aug 2014 5:33 AM Date Created
  • Views 931 views
  • forget_me_not
  • flexible_home
electronichamsters
electronichamsters
29 Aug 2014
  1. [INDEX]
  2. Introduction and project description
  3. Sensor Node and Gateway Design
  4. How I use OpenHAB - audio notification and dashboards
  5. Design detail for wireless sensor nodes and gateway
  6. Uber Sensor - wireless sensor for fire, smoke, gas, barking, light, movement
  7. Diaper Box Sensor
  8. Laundry Room Sensor
The small size and energy harvesting capability means it fits in small places, like the diaper wipe box.  We’re always forgetting to close the diaper wipe box and it dries out.  The EnOcean reed switch sensor is great for monitoring if the top is left opened too long.  And you can use OpenHAB on the Pi to remind you to close it.
OpenHAB Item Definition:
Contact itm_baby_wipe "Baby Wipe [%s]" <contact> (All) {enocean="{id=01:81:3C:A4, eep=D5:00:01, parameter=CONTACT_STATE"}
OpenHAB Sitemap - though not really needed unless you want to remotely view diaper box status image
T
ext item=itm_baby_wipe
OpenHAB Rule - this is where the timer is used to determine when to alarm.  Adjust timer length to whatever you want.
var Timer door_timer = null
var boolean door_left_open = false
var boolean door_first_time = false
rule "baby wipes"
when
    Item itm_baby_wipe changed
then
        if (door_timer != null)
                door_timer.cancel()
        if (itm_baby_wipe.state == OPEN)
                door_left_open = true
                door_timer = createTimer(now.plusSeconds(60)) [|
                        say("Baby Wipe Door Left Opened")
                        door_first_time = true
    } else {
end
rule "Check every 2 minutes"
when
    Time cron "0 0/2 * * * ?"
then
    if ((door_left_open == true) && (door_first_time == true) {
        say("Door still left open")
end
If someone could tell me how to put the code in those nice code blocks like the other people in this competition, I'd appreciate it!  Thanks Mark!
Also, thanks very much to Kimmo for helping me with my EnOcean issues earlier.
    mcb1 over 12 years ago
    Eric
    Its a bit cryptic
    Click on the >> and you'll get a choice.
    Not sure what the others have chosen but try one or two.
    be warned that sometimes this highlighting thinks the text is Excel and try's to put it into rows and columns.
    Eric
    Its a bit cryptic
