Blog Forget Me Not: Episode 12: An Update
  • Author Author: michaelwylie
  • Date Created: 9 Oct 2014 6:39 PM Date Created
  • Views 1107 views
  • forget_me_not
  • iot_auto_monitor
michaelwylie
michaelwylie
9 Oct 2014
Previous Posts:
Epidode 1: Forget Me Not: Application
Episode 2: Forget Me Not: The Best Laid Plans ...
Episode 3: Forget Me Not: Setup EnOcean with openHAB
Episode 4: Forget Me Not: Medication System
Episode 5A: Forget Me Not: Using Notify My Android with OpenHab
Episode 6: Forget Me Not: Plant Watering System Design
Episode 7: Forget Me Not: Medication System Demo
Episode 8: Forget Me Not: Using Twitter
Episode 9: Forget Me Not: Sunshine, Lollipops, and Rainbows
Episode 10: Forget Me Not: It's so hot!
Forget Me Not: Episode 11A: Watering System Construction
Forget Me Not: Episode 11B - Soil Sensor Design
There is no major progress from my last post. I'm waiting on parts. I mentioned previously that I used a portion of my budget to stock general parts like:
  • Resistors
  • Capacitors
  • Inductors
  • Fuses
  • Connectors
  • Diodes
  • Transistors
  • and the like
However, I waited until my second order to purchase these items because I needed to acquire the major components of my design first. Here I should add an obligatory kudos to dragonstyne (Steve) for his insightful comment to me when I revealed my initial Gantt Chart (project timeline)image
He was completely correct, and I think his comment shows his experience in procurement. I think everyone involved in RoadTests has noticed the comments about heavy volumes at the warehouse and expected delays. Delays are a part of engineering, and a good engineering plan can be adjusted to account for delays. The guy I work with just ordered some vacuum pumps and the lead time is 1 month. It didn't phase him a bit and he adjusted the timeline so everything will still be on schedule. However, I think my inexperience in project planning shines through here because my project doesn't have this quality. I've been working in industry for 1 year and 4 months now, and none of my projects have been on-time.
If I recall correctly, somewhere between my first and second order Newark initiated the same day shipping policy. I think this may be causing the RoadTest delays, but that's pure speculation. There are 15 days left in the challenge, and I haven't been able to work on the air conditioning switcher yet. I want to produce a document for this design as well, so I have to decide when to stop designing and start writing. The purpose of the document is to completely, and transparently release my work into the public domain.
  • dragonstyne
    dragonstyne over 12 years ago
    Michael, you are a clever fellow and I'm sure you will find a way to improvise until, hopefully soon, supply catches up.
    Thanks for the kind words.
    -Steve
  • fvan
    fvan over 12 years ago
    That's a bummer, especially when it's out of your control ...
    I hope you still manage to finish most of your project without it!
  • michaelwylie
    michaelwylie over 12 years ago in reply to shabaz
    I've been compiling my list. Every time I go to build something I realize I should have ordered something else image.
    shabaz over 12 years ago
    Hi Michael,
    Pretty impressive to see a gantt chart : )
    It was good that you did stock up on the essentials anyway, nothing worse than having to pause a project for want of a generic diode or resistor. I keep a basic spreadsheet (not extremely accurate, but good enough) so I can remember what I already have.
    Good luck with the next couple of weeks!!
