Blog Pas Home / PiTFT
  • Author Author: verrverr
  • Date Created: 7 Sep 2014 4:30 AM Date Created
  • Views 1175 views
  • forget_me_not
  • pas_home
Pas Home / PiTFT
verrverr
verrverr
7 Sep 2014
Pas Home - Index
This week a play with the PiTFT from Adafruit https://www.adafruit.com/products/1601, also available on newark Product LinkProduct Link
I want use the PiTFT with Pi for made a control panel to install in my kitchen and easily open/close my curtain, view and change heating temperature and control my home ventilation.
Setup
This is the procedure a use to setup my device https://github.com/pascalmartin/ForgetMeNot/tree/master/bundles/pitft
Usefull tips
  • To startx to HDMI Display
FRAMEBUFFER=/dev/fb0 startx
  • To open a console after start with browser in full screen Press CTRL+ALT+F1 and hit return and enter your login
Pi Installation
More complete documentation on Adafruit
Summary :
Step 1
Prepare Micro SD card:
  • Download RASPBIAN Ready to go image with PiTFT ready from Adafruit
  • Format SD Card with SDFormatter.exe
  • Write Raspbian with win32diskimager-v0.9-binary
Step 2
Pi configuration
  • Boot Pi with PiTFT on it, extend file system and configure password, timezone and keyboard reboot
  • Configure wifi using WiFi Config utility
Use this command to startx using the hdmi display (Very more usefull for configure WIFI)
The normal startx command use PiTFT display
  • Logout and Reboot
sudo reboot
  • Update raspberrypi
sudo apt-get update
sudo apt-get upgrade
sudo reboot
Step 3
Change Pi hostname for easily identification on your wifi router Details
sudo sed -i 's/raspberrypi/RPi-PiTFT/g' /etc/hosts
sudo sed -i 's/raspberrypi/RPi-PiTFT/g' /etc/hostname
sudo /etc/init.d/hostname.sh
sudo reboot
Step 4
Auto run browser on startup
Some resource :
  • http://blogs.wcode.org/2013/09/howto-boot-your-raspberry-pi-into-a-fullscreen-browser-kiosk/
  • (Not tested) http://www.raspberry-projects.com/pi/pi-operating-systems/raspbian/gui/auto-run-browser-on-startup
Summary:
  • Install dependency package
sudo apt-get install matchbox chromium x11-xserver-utils ttf-mscorefonts-installer xwit sqlite3 libnss3 sudo reboot
  • Adding the following to /etc/rc.local:
if [ -f /boot/xinitrc ]; then
  ln -fs /boot/xinitrc /home/pi/.xinitrc;
  su - pi -c 'startx' &
fi
  • Create xinitrc file /boot/xinitrc
#!/bin/sh
while true; do
  # Clean up previously running apps, gracefully at first then harshly
  killall -TERM chromium 2>/dev/null;
  killall -TERM matchbox-window-manager 2>/dev/null;
  sleep 2;
  killall -9 chromium 2>/dev/null;
  killall -9 matchbox-window-manager 2>/dev/null;
  # Clean out existing profile information
  #rm -rf /home/pi/.cache;
  #rm -rf /home/pi/.config;
  #rm -rf /home/pi/.pki;
  # Generate the bare minimum to keep Chromium happy!
  #mkdir -p /home/pi/.config/chromium/Default
  #sqlite3 /home/pi/.config/chromium/Default/Web\ Data "CREATE TABLE meta(key LONGVARCHAR NOT NULL UNIQUE PRIMARY KEY, value LONGVARCHAR); INSERT INTO meta VALUES('version','46'); CREATE TABLE keywords (foo INTEGER);";
  # Disable DPMS / Screen blanking
  #xset -dpms # disable DPMS (Energy Star) features.
  #xset s off # don't activate screensaver
  # Reset the framebuffer's colour-depth
  #fbset -depth $( cat /sys/module/*fb*/parameters/fbdepth );
  # Hide the cursor (move it to the bottom-right, comment out if you want mouse interaction)
  #xwit -root -warp $( cat /sys/module/*fb*/parameters/fbwidth ) $( cat /sys/module/*fb*/parameters/fbheight )
  # Start the window manager (remove "-use_cursor no" if you actually want mouse interaction)
  #matchbox-window-manager -use_titlebar no -use_cursor no &
  matchbox-window-manager -use_titlebar no &
  # Start the browser (See http://peter.sh/experiments/chromium-command-line-switches/)
  chromium --app=http://192.168.0.150:8080/openhab.app?sitemap=demo
done;
  • Reboot
sudo reboot
Step 5
Configure tactile switch as power button From Adafruit
gpio pin from left to right : 23, 22, 21, 18 (I'm not use 23 because is on top of usb connector and the metal short the switch, i need a case)
Summary:
  • Add rpi_power_switch to /etc/modules
sudo sed -i '$ a\rpi_power_switch' /etc/modules
  • Append options rpi_power_switch gpio_pin=18 mode=0 to /etc/modprobe.d/adafruit.conf
sudo sed -i '$ a\options rpi_power_switch gpio_pin=18 mode=0'  /etc/modprobe.d/adafruit.conf
  • To make it active immediately run sudo modprobe rpi_power_switch or reboot
    mcb1 over 12 years ago
    Nice.
    I'm still waiting on two I kickstarted, and he seems to have gone to ground unfortunately.
    I always dislike shields and other items that rely solely on a connector for physical attachment.
    You could stick a bit of mylar onto the USB using double sided tape.
    Nice.
