Blog Pas Home / Second equipment reception
  • Author Author: verrverr
  • Date Created: 15 Aug 2014 2:49 AM Date Created
  • Views 2135 views
  • Comments 10 comments
  • forget_me_not
  • pas_home
verrverr
verrverr
15 Aug 2014
Pas Home - Index
Hi, I thought today receive my order equipment for my project, but here's what I got
Salut, je pensais recevoir aujourd'*** ma commande de matériel pour mon projet, mais voici ce que j'ai reçu image
EnOcean EDK 350 and Tektronik TBS 1052B-EDU
EnOcean EOP 350
J'ai aucune idée comment un oscilloscope peut fonctionner, est-ce que vous connaissez de bonne vidéo ?
I have no idea how an oscilloscope can work, do you know a good video?
  • ipv1
    ipv1 over 12 years ago in reply to mcb1 +1
    Thanks. I am considering moving to Australia once I finish my PhD. I want to work where Dave Jones of eevblog has his lab. The garbage room had more stuff that the local market where I live. Australia…
  • michaelwylie
    michaelwylie over 12 years ago
    Again, a mistake occurred? I thought you were supposed to get the EnOcean Pi and the 1202B-EDU
  • fvan
    fvan over 12 years ago in reply to michaelwylie
    Michael, I posted a comment to get a clarification, as it seems others have received the same package.
    Pascal, don't worry, I'll have to learn how to use it also. Let's share experiences image
    Frederick
  • fvan
    Frederick
    mcb1 over 12 years ago in reply to fvan
    You might find the EnOcean package is simply the EOP350 programmer a transceiver module and a USB cable.
    The full EDK350 includes some other parts.
    Look for an announcement about the scope.
  • ipv1
    I have a question. Did you guys get the EOP350 programmer as part of the package itself? I was looking at the programmer and it was part of the EDK and very EXPENSIVE!
    mcb1 over 12 years ago in reply to ipv1
    Inderpreet
    My package hasn't arrived, however in the discussions it was suggested that to change some of the modules you would need a programmer, so I ordered the EPK350 which has a programmer.
    EPK 350 - ENOCEAN - PROGRAMMER KIT, ESK300 UPGRADE | element14 India
    Your price in India is rather expensive compared to the AUS/NZ price (which might have been a special).
    The details of the programmer are here so you might be able to knock together something.
    http://www.enocean.com/en/enocean_modules/eop-350-user-manual-pdf/
    mark
  • verrverr
    verrverr over 12 years ago in reply to mcb1
    Désolé de mon erreur effectivement j'ai pas reçu le pack SDK 350 mais juste le programmeur EOP 350 (A special receiver module from EnOcean), j'ai utiliser le code que l'on peut voir sur la photo avec des instructions.
    Sorry my mistake I actually have not received the SDK pack 350 but just the programmer EOP 350 (A special receiver module from EnOcean), I use the code that you can see in the picture with instructions.
    Frederick Vandenbosch
    I found this comment from Christian: The Forget Me Not Design Challenge - The Finalists
    Where he indeed mentions:
    The Oscilloscopes will follow on shortly, along with a special receiver module from EnOcean.
    So that "special receiver module" will be the EOP350 + transceiver you mention.
    Not sure where to find the announcement regarding the scope though. Must've completely missed it.
    Frederick
  • ipv1
    Thanks. I am considering moving to Australia once I finish my PhD. I want to work where Dave Jones of eevblog has his lab. The garbage room had more stuff that the local market where I live. Australia seems to have an edge.
    Cheers.
