Blog "Remember Me Always!" - Part 022
  • Author Author: COMPACT
  • Date Created: 14 Oct 2014 8:17 PM Date Created
  • Views 1284 views
  • Comments 5 comments
  • forget_me_not
  • raspberry
  • pi
  • raspberrypi
  • rpi
  • remember_always
COMPACT
COMPACT
14 Oct 2014
Formal Wear for the Raspberry Pi
I've made my own HAT for my Model B+ Raspberry Pi. It's dimensions meet the official specifications and includes the slot for the camera cable and the notch for the LCD cable.
My HAT provides me with
  • HAT ID Autoconfigure EEPROM
  • I2C connector
  • Serial Port Connector
  • 2 x PMod SPI Connectors
  • DS1721 I2C Thermometer
  • MCP23017 I2C 16 bit I/O Expander
and soon also support the 1-Wire Interface
The board was designed also alternately host a PSoC. Unlike the lucky few I didn't receive a RPiSoC so I effectively made my own but with "Extras".
Old habits die hard so as per usual I've laid the board manually without the assistance of any schematic capturing.
And then milled and drilled a PCB.
Weeded and cleaned it up.
You may notice a bit of over engraving on a couple of tracks. This is a due to PCB substrate warpage but since it is just a prototype it can be easily repaired.
Being a prototype, being manually laid out and never being assembled before one does not just solder on all of the components and prey that it works.
That's a sure fire recipe for unmitigated disaster.
The first section assembled and tested was the HAT's ID EEPROM section.
Once this was up and working correctly.The next part was the MCP23017 I/O Expander
And then the DS1721 Thermometer was added (pictured in the first photo of this article).
All of the devices were accessible from the Raspberry Pi.
And finally exported GPIO, RS232 and SPI ports were tested and confirmed working.
Although not pictured LEDs and a DSO was connected up to verify correct operation.
Test programs were written in C on the Raspberry Pi. It included test programs to blink LEDs on the GPIO and MCP23017 IO ports.
Then a PSoC4 was connected up to the via the I2C, RS232 and SPI ports and was verified to work correctly.
The 1-Wire Interface will be connected up as soon as the part arrives.
  • hlipka
    hlipka over 12 years ago
    So the board worked in the first try? Great Job! But you did use Eagle (or another PCB design tool) for it, right?
    Where did the PSoC go on that PCB? Bottom side?
  • hlipka
  • COMPACT
    COMPACT over 11 years ago in reply to hlipka
    Have a look at this post for EAGLE and milling.
    http://www.element14.com/community/people/COMPACT/blog/2014/11/14/not-my-first-blog-post
