Forum programmer for EnOcean?
  • Replies 9 replies
  • Subscribers 7 subscribers
  • Views 2100 views
  • forget_me_not
  • enocean
electronichamsters
electronichamsters over 12 years ago
This is my first time playing with EnOcean products.  If I want to utilize the GPIO on the STM330 temperature sensor, the manual gives a method of doing so, but it requires either the USB300 USB-SPI adapter or the development board.  I was hoping that would come with the sensor kits, but I didn't get one.  Did anyone receive one with their kit?
Does anyone know of some alternate method of programming the STM330?  Being able to program it opens up a world of possibilities...most of what I was hoping to do with it.
  • electronichamsters
    electronichamsters over 12 years ago in reply to michaelwylie +1
    Yes, I think you're right, that's the dev kit that's referenced. Thanks.
  • michaelwylie
    michaelwylie over 12 years ago
    I was under the impression you needed the programmer. Would this work?
    EPK 350 ENOCEAN Energy Harvesting Development Kits | 98W2541 | Newark element14
  • michaelwylie
    michaelwylie over 12 years ago in reply to electronichamsters
    It would be a large chunk of the budget. Looks like you have a decision to make image
    Hi Eric,
    Temperature sensor STM 330 can be configured and programmed.
    Configuration will set new parameters e.g. for manufaturer ID, wake-up and measurements cycles etc.
    Writting new firmware for STM 330 is also possible with the libraries from EnOcean, however you
    need ARM Keil uVision to program the 8051 core. The PC Software DolphinStudio supports both.
    In order to connect STM 330 with the PC you need a programmer which is part of EDK 350 or
    EPK 350,
    Markus
  • verrverr
    verrverr over 12 years ago
    Hi i receive with the free Tektronik oscilloscope the EDK 350 also free, i think you are not need to buy one
    Pas Home / Second equipment reception
  • michaelwylie
    michaelwylie over 12 years ago in reply to verrverr
    A mistake occurred? I thought you were supposed to get the EnOcean Pi and the 1202B-EDU
  • ravi_butani
    ravi_butani over 12 years ago in reply to verrverr
    imageYeah...Christian wrote about this... Tek DSO will be shipped with special enocean kit... I m also waiting for the same...
  • chaoztc1
    chaoztc1 over 12 years ago
    programmer for raspberry pi:
    https://github.com/ctc/re_programmer
  • chaoztc1
    chaoztc1 over 11 years ago in reply to chaoztc1
    howto modify enocean pi module to be used with re_programmer:
    https://www.facebook.com/media/set/?set=a.10205187478673489.1073741827.1441149094&type=1&l=1d65173abc
