      • Japan
      • Vietnam
In the Air Design Challenge
  • In the Air Design Challenge
Blog AirMobile - 21 - The board
  • Author Author: amgalbu
  • Date Created: 26 Jan 2015 10:27 AM Date Created
  • Views 1078 views
  • Comments 5 comments
  • iot_distributed
  • ltc3108
  • in_the_air
  • energy_harvesting
  • peltier
amgalbu
amgalbu
26 Jan 2015
Finally I (almost) completed the AirMobile sensor board
Here it is
If you think it's awful, I agree with you... I made too many mistakes, but component's  bottom views always confuse me.
Anyway, to complete the board I have to
  1. mount the MiCS2710 sensor
  2. mount the Bluetooth module
The next step is to test the power supply section...
    shabaz over 10 years ago +1
    Hi Ambrogio, It's not so bad at all - everyone makes mistakes on PCBs. My only solution to minimise this is to never submit gerber files until I'm feeling super-alert enough to re-study it (which is a…
  • amgalbu
    amgalbu over 10 years ago in reply to mcb1 +1
    Thanks mcb Fortunately I made just one mistake, in that I ordered just one PCB due to budget limitations...
    mcb1 over 10 years ago
    There is usually something that needs changing on every board, so think of this as the prototype or pre-production version.
    Many years ago we used to get Radio Telephones from a large NZ manufacturer that had almost as many components on the bottom as the top ... and this was the days long before Surface Mount Devices.
    I fairly sure we used to be supplied the pre-production, so I wouldn't be panicing until you repeat the same problem.
  • amgalbu
    Thanks mcb
    Fortunately I made just one mistake, in that I ordered just one PCB due to budget limitations...image
  • amgalbu
    Thanks mcb
