In the Air Design Challenge
  • In the Air Design Challenge
Blog In The Air: Epidose 1: Introduction
  • Author Author: michaelwylie
  • Date Created: 24 Oct 2014 7:12 PM Date Created
  • Views 2042 views
  • Comments 8 comments
  • iot_particle_counter
  • in_the_air
michaelwylie
michaelwylie
24 Oct 2014
I've been selected as a finalist for the In The Air Design Challenge. Firstly, I must provide this disclaimer:
I am the Senior Electrical Engineer for Hal Technology. I design hand-held and portable gas meters and particle counters. My idea for this project is definitely not a novel concept, but with the improvement in technology it is more viable. Essentially, as is stated in the project descriptions, I will create a Particulate Matter meter to be embedded in Heating, Ventilation, and Air Conditioning units. The result will be a smart home based sensor that can be used on a WiFi network to monitor a household's air quality.image
Good luck to all the competitors.
  • fvan
    fvan over 12 years ago +1
    This challenge seems to be right in your field of expertise. But I won't be intimidated so easily! Looking forward to this exciting new challenge. Good luck to you too! Frederick
  • michaelwylie
    michaelwylie over 12 years ago in reply to fvan +1
    Well, I don't have a cat. Not a real one anyway ... I do have a Garfield Beanie though. I suppose the petting cat thing was misleading, but I was trying to impersonate a James Bond villain.
    mcb1 over 12 years ago in reply to fvan +1
    You missed your chance. "... We are so convinced you'll want CaTS that we will supply a cat if you don't have one...." Mark
    Nice project Michael.
    It has opportunities at nearly every commercial building.
    Our system has a sensor for smoke, that will shut down the fresh air intake should the source be external.
    shabaz over 12 years ago
    Hi Michael, good luck with the project!!
    I bet everyone is extremely curious to see what sensors you use and recommend : )
  • fvan
    fvan over 12 years ago in reply to michaelwylie
    It's a bit macabre perhaps, or a sign of being a true villain, but a stuffed cat can still be pet ...
  • michaelwylie
