In the Air Design Challenge
  • In the Air Design Challenge
Blog In The Air: Episode 3 - Surface Mount Beginnings
  • Author Author: michaelwylie
  • Date Created: 8 Nov 2014 11:35 PM Date Created
  • Views 1875 views
  • Comments 8 comments
  • iot_particle_counter
  • in_the_air
michaelwylie
michaelwylie
8 Nov 2014
Previous Posts
In The Air: Epidose 1: Introduction
In The Air: Episode 2 - Preparing for Surface Mount Work
I've been combining some "Working With Surface" mount material for this weeks post. The target audience will be anyone who has soldered previously, but has not done surface mount and anyone who could use a few more tricks to add to their repertoire. We'll be covering surface mount soldering using an iron and using paste. If you're not a fan of watching videos, you won't like this post, as I have used videos to show the soldering process.
The Demonstration
This video demonstrates:
  • The setup for surface mount work
  • Removing components with hot air
  • Soldering surface mount components onto a board without using hot air
  • Soldering surface mount components onto a board using hot air
  • Using a solder sucker
The Magnifier Shows
My lamp magnifier showed up after I created the video above, so I made another short video demonstrating the use of the unit.
Conclusion
That's it for now. I hope it's useful when it comes time to solder your project. Good Luck!
  • michaelwylie
    michaelwylie over 11 years ago in reply to michaelkellett +1
    I'd love to test a reflow over for Element 14, hint hint wink wink. haha!
  • michaelwylie
    Thanks guys. I hope I can get some more info up when I go to solder an actual board. image
  • michaelwylie
