Inductive Sensing
  • Inductive Sensing
Inductive Sensing
Blog Inductive Sensing Design Challenge: Portable Detector based on the LDC1000 (#4)
  • Date Created: 12 Jun 2014 10:55 AM Date Created
  • Views 613 views
  • inductive_sensing
  • inductive_sensing_challenge
  • farnell
  • ldc1000
  • texas_instruments
  • road_test
  • cypress
e14 Contributor
e14 Contributor
12 Jun 2014
Since my last blog post I have created a custom coil. It is a 14cm coil with 7 turns of 0.4mm enamelled copper wire.
For the purpose of finding the correct value of the filter capacitor, I ordered capacitors in the range from 20pF to 100nF as specified in the documentation.
I started testing with a 100pF filter capacitor. With this capacitor I get a reading but the sensitivity is very low.
I find calculating Rp_MIN and Rp_MAX rather complex and I am still working on that. After this I have to calculate the correct filter capacitor.
There were some holidays so I could not work on this project very much.
Previous post:
Inductive Sensing Design Challenge: Portable Detector based on the LDC1000 (#3)
