Internet of the Backyard
  • Internet of the Backyard
Blog RPI B+ and the EnOcean Sensor Kit Overview of Up Comming Blogs and Videos
  • Author Author: Robert Peter Oakes
  • Date Created: 4 Sep 2014 4:22 AM Date Created
  • Views 1668 views
  • Comments 7 comments
  • enocesn
  • iot_backyard
  • enocean-pi
  • rpib+
  • internet_of_things
  • raspberry_pi
  • raspberrypi
  • iot
Robert Peter Oakes
Robert Peter Oakes
4 Sep 2014
This is an introduction to two videos I am producing to show the setup of the new RPI B+ and then the installation of the EnOcean Pi module and first time use of the Sensor Kit
The PI Setup including WIFI Raspberry PI Model B+ Quick Set-up (1/2 Hour Guide from unpack to GUI and WIFI)
EnOcean and Fhem setup Raspberry Pi B+ and the EnOcean Sensor Kit - install and initial testing
you will se in the videos that the process to go from boxed PI B+ board and empty SD card to a working system is no more than about 30 Minutes
Then you will see how the prep and subsequent install of the EnOcean drivers and Fhem home automation software will take over an hour to complete due to a rather long process of updating the firmware and libraries of the PI, but be patient, it will get there
In later videos we will look at publishing out the data from the PI to the internet web site EVRYTHNG - Every Thing Connected where you can track, personalize and generally watch / manage your IoT device, go have a look, it is an interesting site and you may find it handy for one or more of your projects
    shabaz over 11 years ago
    Hi Peter,
    This is good stuff! You might want to check out Axel's post, he had some useful info on EVRYTHNG to help accelerate your project.
    mcb1 over 12 years ago
    Peter.
    I do agree that the extra cover would be nice.
    You seem unable to buy it, and it looks awful if you stick it on the wall like that.
    Here the full version is $110 (but no longer stocked) and comes with an extra surround like you'd find on a normal light switch.
    I brought 2 of the ECT310 and 2 of the ECO200 to look at using them together with the EnOcean transmitter module.
    DAB over 12 years ago in reply to mcb1
    Cool
    Thanks Mark,
    mcb1 over 12 years ago in reply to DAB
    EnOcean are very good with the documentation.
    You'll find the answer here.
    http://www.enocean.com/en/enocean_modules/eco-200-data-sheet-pdf/
    DAB over 12 years ago in reply to Robert Peter Oakes
    Ok, no rush.
    Just curious.  I can see some useful designs with that capability.
